Old 04-05-2004, 04:52 PM
gundamcivic gundamcivic is offline
HELP! transmission/clutch noise
hey, i just recently bought a 1992 honda civic si hatch and have had a problem with it, as soon as i start the car, there is slight scraping noise in the transmission. it sounds like the clutch plate is rubbing in the trans somewhere cause if i press the clutch in it goes away. its not to loud right now but rubbing metal is usually bad news in any situation on a car. im pretty sure its something rubbing cause if i wiggle the shifter the noise changes pitches but continues till i press in the clutch. the car still runs and performs fine but it probably won't stay that way. if any one has had this problem please tell about it.
thanx
Old 04-07-2004, 01:14 AM
BullShifter's Avatar
Re: HELP! transmission/clutch noise
The noise your hearing is most likely an internal bearing called - input shaft bearing. Input shaft bearing go bad from incorrect DOWNSHIFTS. If the bearing is bad, I'll bet 2nd gear/synchro is chewed up. If I were you I'd start looking for a good used or rebuilt trans. Your '92 trans probably has high miles & not worth rebuilding.
The noise from shifter is normal just the fork & synchros moving, shafts.
Old 04-07-2004, 12:06 PM
Question thanx
hey thanx alot man, hopefully that aint to expensive, oh yah just one more question, how long is that gonna last?? is it like somethin i need to fix right away or can it wait like a month or two??
Old 04-07-2004, 06:47 PM
Re: thanx
To remove the trans is about 3.0hrs labor(book time), re-install 3.0hrs, plus an hour or so to replace the bearing. You can get a used trans for $300 & pop that in. I could be wrong, it's hard to fix a noise without hearing it.
If you can change spark plugs, you can pretty much do anything on a civic 4-banger. 1 of the easiest cars to work on IMO. Having a repair manual from www.helminc.com will walk you through the entire car, including trans R&R.
I drove my car for 20K miles with a bad input shaft bearing. Started out soft & by 20K it was loud as hell. When that bearing does break loose your tans will lock-up.
Help! 94 2jz 6spd...transmission noise warman724 General 1 11-29-2009 09:21 AM
1991 Camry Problems, HELP!! toyota_camry Camry/Camry Hybrid/Vista 4 04-10-2009 08:15 PM
help with clutch or transmission problem WaL802000 General Discussion 2 03-01-2005 06:30 PM
Help!! Clutch noise. keston256 General Discussion 1 04-13-2004 01:24 PM
HELP!!! Transmission noise 97primera Engine 0 03-12-2002 07:55 PM
