Go Back   Automotive Forums Car Chat > Isuzu > General Discussion
Old 02-26-2005, 02:19 PM
WaL802000 WaL802000 is offline
Question help with clutch or transmission problem
Hello,
I have a 1989, 2.6L, isuzu pickup truck and my question involves the clutch/transmission.
When i try to start my truck (with a working battery) it acts as if the battery is weak, but after it starts there is a grinding/knocking noise and the engine rumbles while the clutch is pressed to the floor, but when i release the clutch it runs normal until the clutch is pressed again.
My slave cylinder is less than a year old and the master cylinder is maybe 2-3 years old.
should I bleed the clutch system again or may this be a transmission problem relating to the release bearing?
thanks for any help.
Old 02-28-2005, 08:12 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: help with clutch or transmission problem
check crankshaft end play
Old 03-01-2005, 06:30 PM
thanks for the response and help.
I bled the clutch system again and made sure the oil level in my transmission was correct and it stopped the knocking noise while the clutch was engaged (pressed), but when I am accelerating there is a slight knocking noise as long as I am giving it gas, but there is no knocking when I am sitting at a light or normal idling.
Is the problem the crankshaft play as mentioned earlier? and how serious could this problem be?
Also how do I check the play in the crankshaft? by inspecting the pulley or trying to break the engine down?
thanks for any help
