Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-05-2004, 02:42 PM
condo0000 condo0000 is offline
Plug Keeps Melting???
Hello,
I originally had a problem with the power output (couldn't even make it up a small grade). I changed the wires, plugs and EGR valve. When I took the plugs out one of them looked really bad. The new plugs were in for only about a week. The problem came back. When I looked at the plugs again the same plug was burned down past the electrode.
Any ideas of what could be causing this?
Thanks,
Craig
Old 04-05-2004, 06:34 PM
Notorious_Ford_Guy Notorious_Ford_Guy is offline
Send a message via MSN to Notorious_Ford_Guy Send a message via Yahoo to Notorious_Ford_Guy
Re: Plug Keeps Melting???
did you gap them properly?
JK
1995 Ford Thunderbird
1992 Ford Explorer
1990 Ford F-150
Old 04-06-2004, 07:40 AM
It is a 92 Explorer. Yes, they were gapped properly. Actually, I just burned out another plug (same one) in a weeks time. Don't know what could be causing this. I would guess that if the same cylinder keeps burning up that it would mean that it is running too lean. That may indicate that the fuel injector may be bad?? Any other ideas??
Thanks
Old 04-09-2004, 07:18 PM
amac209 amac209 is offline
Send a message via MSN to amac209
check for a plugged catalytic convertor. everything gets red hot most when they're plugged. might also have carbon build up causing detonation.
Old 04-11-2004, 09:17 AM
Twist'n-Wrenches Twist'n-Wrenches is offline
The things that cause an electrode to melt are incorrectheat range on the plug(not your case as only one plug with problem),over advanced timing(same as above), lean fuel mixture (could be a plugged injector), insufficient coolling (blocked cooling passage not to common), lack of lubrication (should see other signs of that). My bet would be a lean condition ie plugged or poor flow of the injector on that cylinder. Good Luk Greg North of 60
melted coil pack cedarjames Intrepid 3 07-12-2010 09:51 AM
2001 2.2l #1 cylinder plug is melted down! Please help! Timing?!? slurfius Cavalier Problem Diagnosis 0 05-05-2008 10:58 AM
My truck keeps melting its cats!!! blk12b Explorer | Explorer Sport Trac 3 11-13-2006 12:25 PM
Spark Plugs keep filing down, Stalled takeoffs MarkJMarine Tahoe 5 06-04-2006 11:25 AM
changed plugs keep fouling procrstinator Alero 3 04-06-2006 06:21 PM
