Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-05-2004, 02:14 PM
slade2625 slade2625 is offline
I30 Bose Speaker
I recently purchased a 2000 Infiniti I30 and discovered after closing the deal that no sound is issuing from the rear speaker (above the back seats). I checked the fade setting and the wiring and everything looks good...just no sound.
Does anyone have any advice on how to correct the problem?
Thanks!
Old 04-05-2004, 08:27 PM
RaZeDOuT RaZeDOuT is offline
No sound suppose to come out of that speaker....thats a subwoofer...just gives off Bass...
Old 04-06-2004, 11:22 AM
SkyTorch's Avatar
SkyTorch SkyTorch is offline
Re: I30 Bose Speaker
Bass is still sound. But, as was mentioned, it is a woofer. If the overall sound has no bottom end, then check the wires in the trunk. So if all things are right and nothing is coming out, you may end up replacing it.
Sidebar: Bose in-dash systems are not powered. The power is at the speakers with a built-in amp, i.e. speaker and amp as one unit. At least it's that way in the back. I haven't pulled the ones out of the door.
Old 04-07-2004, 02:00 PM
Hey thanks for the input!
I did check the wiring in the back and it looks good as far as I can tell - still no sound...bass or otherwise.
I hate to think about replacing the speakers but it may come to that.
Any recommendations on sources to obtain the speaker and/or the amp?
Again, I appreciate your help.
Slade
Old 04-08-2004, 01:51 PM
SkyTorch's Avatar
I ha
Old 04-08-2004, 01:54 PM
SkyTorch's Avatar
I have no doubt it will be insultingly expensive. Personally, I looked around for a wrecked car you can strip.
Old 07-24-2004, 01:42 PM
nelrock nelrock is offline
Send a message via AIM to nelrock Send a message via MSN to nelrock
SLADE... It's funny that you should mention this problem because I experienced the same w/my 2000 model. Just as SKYTORCH mentioned it would probably be best that you do look around for a wrecked I30... until then here is what I did to alleviate the problem... REMEMBER THIS SHOULD ONLY BE SHORT TERM!!!!!!!! If you are familiar with aftermarket installations... the main three wires for a power amp are the ground, the power wire and the remote wire which allows the on/off switch to pass current to the amplifier. Under your rear deck resides a small circuit board covered with foam. There should be an orange wire [B+], a black wire [ground] and a blue wire [remote: on/off]. On this circuit board there are two resistors, three diodes and a black box. The black box is your on/off switch for the BOSE amplifier that powers your sub. Before bypassing this box you need to ensure that it is recieving 12vdc with the car off and or 13.25 vdc with the car running. Only perform this task if you are familiar with the use of a multimeter to check the voltage. Voltage should always be present on the side of the switch where the power wire [orange] is in the middle of the configuration. If voltage is present on the other side of the switch, you might have a more serious porblem that could be either your amp or your sub. As for me it was the switch [F&T P1CNO12W] which I am desperatly searching for. I just removed mine and connected the color matched wires from the opposite end of the circuit board. REMEMBER THIS SHOULD ONLY BE SHORT TERM -- REMOVING THIS SWITCH WILL ALLOW POWER TO CONTINUOUSLY BE PRESENT AT YOUR BOSE AMP AND IF YOU DO NOT DRIVE YOUR VEHICLE DAILY - YOU RISK THE CHANCE OF DRAINING YOUR BATTERY! GOOD LUCK!!!
Old 07-26-2004, 12:18 PM
laurennerual17's Avatar
laurennerual17 laurennerual17 is offline
Send a message via AIM to laurennerual17
Thanks!
This is is the easiest...I was told that you have to bypass the whole system because each speaker is powered by its own amp...well what me and my boyfriend did is... If you have an aftermarket stereo...disconnect all the amps from the speakers...which isnt that difficult...and then take the speakers and run them to the back of your stereo...and it works out just fine...cuz u dont know if the connection from the amp to the speaker is messed up or just the speaker so thats a good way to find out...and its quick and easy and a lil cheaper...
Old 09-18-2004, 02:04 AM
GTALCOTT GTALCOTT is offline
Send a message via MSN to GTALCOTT
ebay
Go to ebay, Bose speakers with the amp are always for sale and are usually under 50.00
Old 10-15-2004, 01:25 PM
Final Resolution to Bose Speaker problem
Thanks all for the great feedback on my question.
As it turned out, I went to a stereo shop and they fixed the problem. The relay switch, which I believe nelrock was referring to in his post, was bad and needed replaced. They threw an after-arket replacement part in.
Total out of pocket expenses ran me $30 or so, and I have had the use of my sub since (it sounds great for a factory system).
Thanks again,
Slade
Old 10-15-2004, 09:15 PM
jmrev's Avatar
jmrev jmrev is offline
you should be fine with that.
i30 bose stero with aftermarket deck will it work dghunt Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-13-2006 07:33 PM
2K1 I30 Bose Stereo Questions... Homebrew1709 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 04-08-2005 12:27 PM
2K1 Infiniti I30 Bose Stereo Question Homebrew1709 Car Audio 3 10-08-2004 04:10 PM
bose speakers crossovers Brian P Audio/Security 0 09-08-2001 10:20 PM
Bose Speaker Connector?? G20QT Audio/Security 3 08-14-2001 02:06 PM
