Old 04-05-2004, 12:31 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
confused with mpfi stuff
JDM SOHC ZC OBD0 STYLE INTAKE MANIFOLD
This is an auction for a JDM intake manifold from a SOHC ZC motor. This intake will work on any SOHC civic motor from 88-2001. This manifold comes with the injectors, rail and the throttle body. The JDM unit is a factory replacement and will add some hidden horsepower to your car. This Intake is perfect to replace your worn unit or to upgrade. The JDM version has bigger injectors and larger runners for lower end torque. The injectors that come with this intake are LOW IMEDANCE units. IF you would like to run them in your 92-00 civic you will have to wire in a resistor box. Or put a resistor inline with each injector. You can also use your current injectors in this manifold and skip the resistor box. I have sold a few of these manifolds before but they are getting harder to get so bid now and don't be left out. Good luck and happy bidding. **** In some of the units that are imported from Japan the TPS or other sensor may be damaged due to the engines moving around on the ocean container.**** Any US Sensors will work though. Any US Sensors will work though.
thats the direct quote from the ebay seller, i was under the impression that u needed a resistor box no matter what, i'm thinking of buying this but i wanna know if i still need a resistor box or not, please lemme know
Old 04-05-2004, 12:41 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: confused with mpfi stuff
is ur car dpfi or not? from ur sig it appears dpfi. That IM is identical to the A6 manifold. So, i hope he's not selling it for more because it's JDM; it's the same as the us Si one. Also, you will need the injector resistor box from any honda/acura which all use 6 ohm resistors or you can do like he said and wire up 4 separate 6 ohm resistors. Ur also gonna need the mpfi A6 ecu and dizzy.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-05-2004, 12:58 PM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
how much is that motor? i got a ZC dohc engine longblock plus tranny for $825 to my door from Hmotorsonline.com. it runs perfect and i live in NC so if you're closer to cali i'm sure it would be cheaper. Only reason i ask is because i've been ripped off by good ol, EBayers
Old 04-05-2004, 02:41 PM
1PhatCX's Avatar
yes my car is dpfi, and hes selling JUST the intake for .99 cents, and like 30 bux shipping, i already have a pm6 ecu so that should work too right?? then all i need is the dizzy correct?
Old 04-05-2004, 10:27 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
I would say plan on finding a tps sensor since he's pretty much telling you you're not gonna get one... Just go to a wrecking yard and find an Si... Just my $0.02...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 04-06-2004, 10:42 AM
bambam89lx's Avatar
AF - Advisor
well, if it doesn't have a TPS, you can use ANY TPS out of ANY MPFI HONDA/ACURA. They will all work.
Also, yah ur right, ur gonna need the PM6 ecu (which u got) and the dizzy from an 88-91 si. Don't forget that ur also gonna need the injector resistor box.
Old 04-06-2004, 12:31 PM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Re: Re: confused with mpfi stuff
Hey man, what part of NC are you in. I'm in Gastonia, right next to Charlette
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 04-06-2004, 02:33 PM
(i feel like a tard for not reading the whole post) anyways i'm from greensboro.
mpfi stuff needed maxassassin Classifieds 7 02-13-2006 06:02 PM
PM8 ECU And some mpfi stuff FS: Scott82 Classifieds 0 03-16-2005 04:10 PM
confused about mpfi T-Mo '88 - '91 Civic | CRX | Wagon | Shuttlee 3 03-18-2004 10:03 PM
Im SOO confused with this camber kit stuff help!! fyrewyre819 Accord/TSX/Accord Hybrid 6 02-06-2004 06:57 AM
