Old 04-03-2004, 06:08 PM
anatka anatka is offline
Ford windstar dome lights problem
Hello.
I've read and tried all suggestions.
Unfortunately, they don't work for me.
problem: Ford Windstar 98 - dome lights won't go off after vehicle is parked.During the motion, they go off in 10-15 seconds.But when engine is not running - they never turn off.
I checked all door connectors, problem still exist.
So, when I park the vehicle, I have to take off a relay from a fuse box.
Please advise what can be done to fix this mishap.
Thanks.
Old 04-04-2004, 12:22 AM
ModMech's Avatar
ModMech ModMech is offline
Re: Ford windstar dome lights problem
Are there any aftermarket or dealer installed devices on this van? If so, I suspect something is keeping the Lighting Control Module (LCM) powered up with 12V when it should be 0Vdc (key off, ignition off). Without scanning the data from the LCM, there is no way to know WHY the lights are on.
Old 04-04-2004, 02:25 PM
wvugrad92 wvugrad92 is offline
Had the same problem with the dome light. I found that the problem originated in the trunk. The two plunger switches were sticking. Try some WD-40 on them and may result in a better operation. It may not work for you, but it did for me.
Old 04-06-2004, 02:45 PM
Could somebody please explain to me - what are these plunger swithes.
Some people mentioned a ball inside them sticking or something.
could they be illiminated at alll?
Please advise.
thanks.
Old 04-06-2004, 04:53 PM
tarheel4eva tarheel4eva is offline
Send a message via Yahoo to tarheel4eva
no you cannot get rid of them that easy they are part of the assembly. Any use of taking it apart would make it futile. Like the post before you said about the WD-40 it helped me. On sthe sliding door you have two of them one in front and the back spray both of them down with even coating. open and shut you door a couple of times to get the oubricant in there. There was a post before about this problem and to find out which one is the faulty door. turn your ignition on and open each door one at a time. You will hear a ding letting you know that that sensor on the door works. The door that doesn't ding is the one you should try to use the lubricant on. This has helped me alot. no more annoying lights when my car is on before i drive. Hope this helps. if you have further troubles just post your results and I will help you in the direction of where to remove your door panel to have access to the sensors.
Bri
Old 04-06-2004, 09:11 PM
Dear Bri
Thanks a lot for your advise.
It looks like I found what I've been missing - there is no audio signal on my car when any door is opened.my be the dealer who sold me the car took something off.and I'm fighting with lights and there are more problems.
Please let me know what should make a dinging noise.Otherwise, I can not follow your suggestion, which I think is very good.
Old 04-07-2004, 10:47 AM
oh, okay then well i would suggest the oil on all the locks to make sure then go from there. I'm not sure about the where the noise should be coming from, but when I have been under my dash a lot i hear the anoying noise coming from where the fuses are at. So you might want to chack there to see if something is missing or wires are exposed as if something was tyorn out of there. Hope this helps
bri
Old 04-07-2004, 10:48 AM
oh by the way I have a 96 windstar, and I'm not wsure what year you have so they may be different.
Old 04-07-2004, 01:03 PM
Dear Bri
Thanks again.
I oiled all locks, got noise when I'm opening the drivers and passenger doors.When the sliding door or rear door is open - no noise, silence.So, as per your previous message, problems are with those 2 remaining doors.If you don't mind, please guide me to the next steps.
Best regards,
AK
Old 04-07-2004, 07:22 PM
okay then dont forget that both remaining doors have two latches each. The rear door panel you would have to take it off the get access to the sensors. You might want to unplug it and the plug it back in you should be able to hear the ding. If not the the sensor contacts (two small metal blades)may be dirty. A handy Q-tip would work here. I am not sure how to get into the sliding door panels. I sprayed some gun oil on the sliding doors latches. Here is a website to get access to the door panels if you ever needed it: http://www.carstereohelp.com/stereo...dstarFDrSpk.htm But, again spray the latches and work them with a screwdriver to make sure they fall all the way back and lock. Then pull the handle to release it. Hope this helps prevents you fomr going to the dealer to replace the sensors.
Old 04-07-2004, 10:39 PM
flynfol flynfol is offline
I had same problem with my '96. it was both switches in tailgate. the ones connected to the latch mechanism. they are sealed and very little oil with get into them. i even removed them and soaked them in oil. finally disconnected them. you will lose the door warning light for the tailgate, and capability for light when opening the tailgate, but my battery was dying in middle of winter. another fine engineered device from ford.
Old 04-08-2004, 03:53 PM
wick wick is offline
This appears to be a common problem with the 98 .. we don't have any reports of it happening with 96 but knowing Ford it's probably the same defective part..
http://www.carcomplaints.com/Ford/Wi...stays_on.shtml
Ok I *know* I corrected the link in Post #10 when I first posted this, & now that part has been removed. Note to whoever removed it, this is relevant to this discussion & not advertising. I realize linked text gets shortened automatically when posting but in post#10, so did the actual URL.
http://carstereohelp.com/stereoremov...starFDrSpk.htm
Old 04-08-2004, 04:18 PM
I did not have a chance to work with rear door switches yet(rainy days), but what I'm thinking to do is - unplug these 2 swithes and place a paper clip into each plug.
I'm just not sure if the circuit should be opened or closed to make light go off?
Please advise.
Another thing is - when I'm driving, light goes off.
Is there another reason or it's OK.
Thanks.
Old 04-08-2004, 11:34 PM
exactly what happens to our 96. just unplug them, no need for paper clip.
Old 04-10-2004, 02:02 PM
Ladies and Gentleman,we got 'im!
It was a faulty switch on a sliding door - I placed a paper clip into it to close the circuit and get it our of my head.
Thank you all for your help.
Together we can beat ford (no capital letters intentially).
2000 ford windstar master lighting switch light kilroy357 Windstar 3 08-06-2021 01:52 PM
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 11:27 PM
I love the Ford Windstar 1999 serge_saati Cars in General 0 05-09-2009 03:51 PM
1998 Ford Ranger- dome light stays on- timer switch-where? petehanna Ranger | Courier 4 10-16-2006 08:18 PM
ford windstar abs light and traction control light andyrobinson26 Windstar 0 10-16-2005 09:30 AM
