Old 04-03-2004, 01:27 PM
Sleeperstang Sleeperstang is offline
HELP!!! Running way too lean, losing power at full throttle
I have a brand new engine in my 1990 mustang and i am having problems with the car already. it is losing power at full throttle and the motor pings. it also running really really lean. i dont know what the prblem is except maybe that it is being caused form the speed density system. i have a bunch of mods on the car that include:cold air intake, 70mm throttle body upper and lower intakes by edelbrock, phenolic spacer, headers, exhaust, h pipe,. Does anyone know whats causing these problems and know if thay can be fixed by simply converting to mass air?
Old 04-03-2004, 02:20 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Well first things first what fuel pressure are you running at now?
You added a bunch of air intake/exhaust mods but did you upgrade your pump/injectors at all?
How old is the fuel filter?
Double check the timing as well.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 04-03-2004, 04:05 PM
Re: HELP!!! Running way too lean, losing power at full throttle
im running at 30 psi. the fuel filter is brand new. I did not upgrade the pump or the injectors. will that make it run more rich? and how about switching to the mass air? will that make it run more rich?
Old 04-03-2004, 04:56 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
My first question needs to be why is your 90 Mustang running speed density and not MAF?
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-03-2004, 05:01 PM
because the 90' is the year of the body and chasis. it used to be a 2.3 i have a 88' gt motor in it. thats why.
Old 04-03-2004, 06:29 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
my dads 96 bronco had the same problem, we replaced the fuel pump and it fixed it
Old 04-04-2004, 06:10 PM
price111 price111 is offline
Speed density is less adaptable to mods than Mass Air but the mods you list seem OK. The 70mm TB seems a bit excessive if you are running stock heads but shouldn't be the cause of your lean condition.
Check for codes - KOEO and KOER - and see what you may be getting.
How about timing - what's it set at? Too much advance will definitely cause pinging. My 5.0 used to like about 12 degrees - 10 degrees is factory. Don't forget to remove the spout connector when checking timing.
Fuel pump or fuel pressure regulator may be problems, too. Did you check pressure while running?
LOL
2000 Pontiac Sunfire GT Randomly Loses Power Karan Cavalier Problem Diagnosis 19 04-30-2009 06:36 PM
Runs way too hot! MrZydeco Sonoma | S-15 3 08-13-2006 10:24 AM
HELP - 460 running way too rich zehner2004 General Discussion 1 12-04-2005 10:11 PM
even with safc II car is still running way too rich HoosierDrifter 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 28 06-15-2005 08:03 PM
