Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-07-2005, 02:04 AM
HoosierDrifter's Avatar
HoosierDrifter HoosierDrifter is offline
even with safc II car is still running way too rich
i have went through all the settings and directions. i have a early 90's 300zx maf sensor. i have done the 2in and 5 out thing already.. and the car still runs way too rich..lots of spuddering and black smoke..is there anything else i need to program? how would i use the safcII to cure the running rich problem?
thanks
-Dustin
Old 06-07-2005, 02:13 AM
Hawaiiandrifter Hawaiiandrifter is offline
Re: even with safc II car is still running way too rich
i have the same problem as you.
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Is your BOV vented or recirc?
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 06-07-2005, 02:17 AM
slideways...'s Avatar
slideways... slideways... is offline
yeah if you vent the BOV into the air you will run rich regardless of what else you do
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 06-07-2005, 02:27 AM
mines is just into the air but i'll be sure to try and recirculate it into the intake. maybe that will work.
Old 06-07-2005, 02:32 AM
make sure you recirculate it AFTER the MAF sensor
putting it in the front of the intake wont make any difference
it needs to be between the MAF sensor and the turbo
Old 06-07-2005, 05:47 PM
i have the hks ssqv bov...
Old 06-07-2005, 06:54 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
you need the adapto fro that one, then reculc it back as sidways said.
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 06-07-2005, 07:14 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Wrong Wrong Wrong.....
If you have a SAFC, go here and look for Dec.air settings. This will allow you to run open atmosphere BOV. For future reference, your car will only run rich when you let off the gas.
Second, what kind of injectors are you running?
Third, get a wideband or get on a dyno. IN-Out settings are different from car to car. Try different ones to see which works the best for you.
And, lol, the SAFC is to cure running rich. You tune fuel out with it. You can pull fuel at different RPM points. You'll have to search on NICO or 240sxfourms for that one.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 06-07-2005, 07:47 PM
ouups, what will we do w/out u nissanfanatic!
(in a more confident voice) YEAh, its not the resurc thing...
E.K.
Old 06-07-2005, 08:29 PM
thanks nissanfanatic
Old 06-08-2005, 01:55 PM
how can it correct running rich when the sensors that it gets its A/F ratio information from is reading wrong? in order to correct it you would have to run super lean at speed so your car wouldnt die every time you pull up to a stopsign.
Old 06-08-2005, 03:44 PM
240SX Guy
Using the SAFC, the SAFC itself only uses throttle position to control fuel on deceleratoin. AFAIK, it takes readings from when you program it(airflow percentage and throttle percentage) and utilizes your settings to control fuel when you let off the gas. The SAFC will see whatever throttle percentage you programmed at 2k RPM and automatically send whatever MAFS voltage it recorded when you programmed the Dec.air settings. Then when it sees zero throttle percentage, it will send out whatever airflow voltage you programmed in for zero throttle percentage. At least thats my take on it.
Once again, the SAFC only fools the computer. Thats all it can do.
-Cory
12.6@122mph
Old 06-08-2005, 06:34 PM
TatII TatII is offline
you could try using 2in 6 out. thats what i used before i got my jwt.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 06-08-2005, 11:07 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Dude... you guys gotta dyno-tune those SAFC-2's to get them to work properly...
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
