Old 04-03-2004, 12:31 PM
66StangCoupe's Avatar
66StangCoupe 66StangCoupe is offline
Send a message via MSN to 66StangCoupe
Question Exhaust Leak?
With my head under the hood and the engine running I hear a slight "ticking" noise on the driver side above the exhaust manifold. When I got under the car yesterday I heard the same thing next to the transmission? I think it is a leak, however if anyone has heard this before, can you confirm this "ticking" sound. Also, it does get a lot louder while accelerating!?! Thanks in advance.
Build a little, Test a little!
1999 Dodge Ram 1500 (gotta have a truck!)
1966 Ford Mustang (resto project car)
Old 04-03-2004, 12:55 PM
SIKCRX SIKCRX is offline
Re: Exhaust Leak?
yea, exhaust leak
2.3L pumpin out 105 stock horses, WHAT NOW BISHES
Old 04-03-2004, 02:21 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Sounds like an exhaust manifold leak to me.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 04-03-2004, 03:27 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I concur LoL
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 04-04-2004, 12:44 AM
Land Shark Land Shark is offline
Usually exhaust leaks make a popping sound when decelerating.
Old 04-04-2004, 09:32 AM
rerun rerun is offline
you could patch it up, or replace it. its up to you.
(read: pay the 10 bucks for a weldor to do it and save yourself 100 bucks)
Old 04-04-2004, 09:39 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Exhaust Leak?
If you want to be 100% sure it's an exhaust leak, take braided or rubber hose, a few feet long. With one end up to your ear, use the other end and move it around the areas you think are leaking. You will hear the ticking thought the hose in your ear.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 04-04-2004, 04:25 PM
GTStang's Avatar
Stang Guy
Or be a real man and buy a stethoscope already!
Plus you can play doctor with the ladies later! LoL
Old 04-04-2004, 04:54 PM
sure, hold a peice of rubber on a hot peice of metal... j/k.. i know what you mean though (use the little metal rod), just making sure that he does know that before he trys a stethoscope
Old 04-04-2004, 11:23 PM
Re: Exhaust Leak?
Yes, this is true, I was born at night... Not LAST NIGHT however. I do like the idea of the hose though. Thanks.
liquid fuel leaking from exhaust manifold SoullessNihilist Blazer 9 11-15-2013 12:47 PM
exhaust leak fixed. intake manifold leaking! ghostrx7 RX-7 2 04-22-2005 11:10 AM
exhaust leak azconvertible C/K 0 09-15-2003 11:36 AM
exhaust leak clinzybmw318i 3 Series 0 05-18-2003 01:38 AM
Loud motor/Exhaust leak? EliteAccordPH Engineering/ Technical 3 04-28-2002 02:04 PM
