Old 04-27-2002, 01:27 PM
EliteAccordPH's Avatar
EliteAccordPH EliteAccordPH is offline
Loud motor/Exhaust leak?
After a month of not starting my Accord. I started it this morning and it was extremely loud and I got an engine check light. So I check the oil and it was quite low so I added some oil. The light was still on so I shut off the car and disconnected the positive battery terminal. After 5 minutes I reconnected the positive battery terminal and restarted the car. The check engine light went out but it is still loud. So I test drove it around the block and its extremely loud when I acclerate but once I let off on the gas and cruise it sounds normal. I'm pretty sure I have an exhaust leak on the lower/secondary exhaust manifold right before the cat. Am I right?
If so where in So Cal is a good shop to go to?
EliteAccord at Import Love
Old 04-28-2002, 12:29 AM
A20A1's Avatar
A20A1 A20A1 is offline
Send a message via AIM to A20A1
Run something under the car like flower or something easily to blow around... that you can see. then leaving a bit of powder in a flat tray move it along your exhaust pipe... unless there is heavy wind, it is an easy way to see a leak... I'm sure there are other ways.
Also I've notticed a rich mixture gives me a louder exhaust note... but EFI's seem to manage the A/F ratio pretty well so i don't see that as a problem.
-MIKE
"THE REWARD IS IN THE JOURNEY..."
3geez member since: September 11, 2001
Cardomain
89 Accord
95 Corolla
Old 04-28-2002, 12:30 AM
A20A1's Avatar
Check the spark plugs also.
-MIKE
Cardomain
89 Accord
95 Corolla
Old 04-28-2002, 02:04 PM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
After you locate the leak, go to a junk yard and find a wrecked car w/ the part on it thats still in good condition, buy it for like 30 bucks, put it on, and save a few hundred bucks
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
liquid fuel leaking from exhaust manifold SoullessNihilist Blazer 9 11-15-2013 12:47 PM
Loud Vibrating/Exhaust Noise @ 2300 RPM timw300 Rendezvous 0 03-20-2007 10:33 PM
loud motor knock yellow jacket Tacoma 1 12-22-2006 04:38 AM
exhaust leak fixed. intake manifold leaking! ghostrx7 RX-7 2 04-22-2005 11:10 AM
What Is A Loud Ass Exhaust!!!??? vtec accord96 Accord/TSX/Accord Hybrid 19 05-02-2004 04:14 PM
