Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 04-03-2004, 03:10 AM
gtlegacy gtlegacy is offline
crank pully leak
The crank pully on a 63 bug is leaking. how hard is this to replace, do i need to split the case?
Old 04-04-2004, 10:51 AM
boschmann boschmann is offline
Re: crank pully leak
If it's leaking from the rear pulley (the one with the belt to the generator) you could have trouble. There is no seal there, just an oil slinger & press fit pulley to the case. You can try replacing the pulley first to see if that stops it, otherwise its new engine time as the case is worn. I've seen some of the cheap aftermarket pulleys leak because they weren't made to the same quality as the originals. With the right puller you can replace the pulley w/o removing the engine.
Old 04-27-2004, 07:46 AM
mikeyk22 mikeyk22 is offline
they do make seals for dune buggys you could try one
Crank pully and Crank gear 97 2.5....Help toverbo Avenger 2 10-04-2007 09:05 AM
90 Prelude Crank pully fritcr Let's get Technical! 3 06-16-2004 01:14 PM
Keeps killing crank pully wigadigjig Mustang Talk 3 04-06-2004 11:58 PM
Crank Pully HELP! ev0lution7 '88 - '91 Civic | CRX | Wagon | Shuttlee 17 03-21-2003 01:23 PM
gtr lightend front crank pully MR2GTR33 Classifieds 6 01-13-2002 11:18 PM
