Old 04-02-2004, 08:29 PM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
More problems.....
Finally got my Zc running. That's the good part. I'm getting a code 19. That's Lockup Control Solinoid Valve. What the hell is that? When I hit the gas it just barely goes....It doesn't matter how hard you hit the gas (Auto by they way). My c.d. player doesn't work when the car is started but it works when the key is in.What the hell is wrong here?? My headlights are dim. My dashlights are dim too. all my lights are dim now that I think about it. My speedometer and rpm gauge doesn't work. I think the speedometer cable isnt hooked up though. Sorry for the long post and thanks in advance.
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 04-02-2004, 11:53 PM
lilol89crx lilol89crx is offline
Re: More problems.....
well code 19 and car has no balls, tq converter lock up clutch is most likely engaged which creates a 1:1 ratio. the clutch isnt supposed to engage untill your cruising to increase gas milage. its basically another gear so to speak when its engaged. so right now its kinda like tryin to move ur car in your highest gear. id say double check grounds as far as the lights are concerned. as far as the radio im not too sure, maybe the ign switch?
Old 04-03-2004, 05:29 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
maybe you are using the wrong ECU
KoRnSaQ
Old 04-03-2004, 06:44 AM
Easily Distracted
Im using my old ECU from the A6. Thanks. I'm gonna check all my grounds and starter in a lil' bit. I'll post my results.
'92 blue Civic Si
-B17a
ugh...more problems...more headaches DeadBlade89 Cavalier Problem Diagnosis 1 11-22-2007 11:25 PM
Problems, problems, and more problems... Noelles2000TL CL | Inspire | Saber | TL 4 08-05-2004 10:58 PM
problems problems and more problems tacoma man Monte Carlo 1 05-12-2004 09:57 PM
Problems, Problems and more.... Problems. Killa_CRX '88 - '91 Civic | CRX | Wagon | Shuttlee 6 03-02-2004 03:01 PM
Problems, Problems and More PROBLEMS!!!! 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 15 06-21-2003 11:59 AM
