Go Back   Automotive Forums Car Chat > Buick > Century
Old 04-02-2004, 06:24 PM
wirewalker25 wirewalker25 is offline
Question turn signal cam
I have a 91 century. The turn signal will not turn off from a left turn. I bought a turn signal cam but do not know how to get the steering wheel off and the new cam in. please help
Old 04-09-2004, 03:05 PM
bignoisey bignoisey is offline
Re: turn signal cam
You might purchase a Hanes or Chilton's repair manual for your car. There should be a step by step precedure. Take care to exactly follow the air bag removal procedure or you could set it off or confuse the air bag controller so it causes a warning light or worse.
Old 04-21-2004, 11:29 PM
gmcarguy gmcarguy is offline
Re: turn signal cam
disconnect battery if you are air bag equipped.
you will need a steering wheel puller to remove wheel. Once wheel is off remove black plastic cover held on by C clip. remove horn contact. Insert signal spring. Reassemble as removed.
02 Windstar - turn signal problem ethanaw Windstar 12 07-02-2016 10:40 PM
04 Saturn Vue - turn signal keeps clicking even when there's no signal on richter343 Vue 4 07-19-2010 06:20 PM
turn signal right - sometimes KronVickan Crown Victoria 6 01-29-2010 02:14 PM
turn signal lights not working x3mtm Durango 4 01-11-2010 12:49 PM
Installing new turn signal cam Loekee75 Park Avenue 6 06-26-2006 06:59 PM
