Old 04-01-2004, 10:12 PM
op012503's Avatar
op012503 op012503 is offline
Send a message via AIM to op012503
Limited slip???
Sorry if this has been asked before, I didnt see it, but can someone please explain what a limited slip does for a car, where its located and how it works (briefly). Thanks
Old 04-01-2004, 11:28 PM
liquidflame8 liquidflame8 is offline
Re: Limited slip???
it gives power to the wheel with the most traction instead of the wheel with the least traction like an open diff. it's located in the transmission. pretty sure it's in the part that the drive shafts go into.
Old 04-02-2004, 02:23 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
Re: Limited slip???
not to over simplify it but it makes bolth wheels spin, not just one.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 04-02-2004, 03:14 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Just to clarify... It's not a traction control system by any means, as in it won't direct power to ther wheel with more traction. It's purpose like stated above is to keep BOTH wheels spinning constant with eachother for increased handling and grip. Not sure if this applies to FWD or if it's just RWD thing, but there's types of LSDs such as 1.5way and then full 2 way. a 1.5way will disengauge itself upon it's either braking or just no throttle input. a 2way will be enguaged at ALL times. Also LSDs can be set as low as 70-80% (meaning one wheel CAN spin faster than the other around turns, and this is how most LSD's are set) or some can be set to a full 100% lock where both wheels ALWAYS spin at the same rate, even when turning. This can be bad in the sense that it can allow the wheels to hop because both are spinning the same when one may need to spin slower than the other.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-02-2004, 03:19 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
Re: Limited slip???
ok....for instance, im my pop's truck, it was advertised as having a LSD (i think)....and when he goes around corners, he gets inside wheel hop...would this be caused by the lsd??
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 04-03-2004, 03:56 AM
Cali Guy
Re: Re: Limited slip???
If it has an LSD in it (not sure of trucks that do, unless 4x4) and it's RWD and it's the inside REAR wheel that's hopping, then yes it might be that. But is he taking to corners hard, or at a normal speed? If they are hard corners, then more likely than anything else, it's just tire scrub which is the tire hopping as it slides across the pavement from loss of tire grip.
hessemer69 on AIM
Old 04-03-2004, 09:18 AM
PunkAlex's Avatar
yeah its a 4x4 with the towing package....And yeah the rear inside wheel hops. Its happens mostly when its raining so i suppose thats part of it.
Old 04-03-2004, 11:57 PM
strodda strodda is offline
Re: Limited slip???
it also helps with acceleration and it got rid of my torquesteer
Old 04-04-2004, 07:57 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Limited slip???
LSD's are awesome if you have some good rubbers. I've got the stock steelies on my car and the inside wheel spins/hops on hard turns. If I had my rims back on with some good tires, they would pull me into/out of the turn a lot quicker.
Old 04-06-2004, 10:01 PM
integra111 integra111 is offline
Send a message via AIM to integra111
Re: Limited slip???
Is lsd worth the extra money?
Old 04-06-2004, 10:04 PM
Re: Limited slip???
by the way ricochet, that little video clip of the stick guy is awsome. I put it on my desktop ^^
Old 04-07-2004, 07:26 PM
it will help in any app you put it in, but its all up to you if its worth it. it will benefit you more as your power goes up. get some prices on parts and labor and decide for yourself if you want to do it or not. on my setup, im very happy i got it.
Old 04-09-2004, 04:51 PM
DJ_EpHaNt DJ_EpHaNt is offline
Hell ya its worth the money, its going to be almost like having PoziTraction (excuse the spelling). And not exactly like Pozi, but pretty damn similar, unles your car is packin' tons of power...
Ac
Old 04-10-2004, 05:13 PM
Cali Guy
Looks like because of the auto tranny in my '00 DX coupe, my only option for LSD is Phantom Slip...
No manual swap, I CAN make this work!
hessemer69 on AIM
Phantom Grip Limited slip differential agthang Engine 4 08-06-2002 11:40 PM
For Sale: Limited Slip Differential Stormy Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 04-23-2002 01:51 PM
helical limited-slip TraMah Sentra | 200SX (USDM FWD) 1 03-31-2002 03:33 PM
Limited Slip Maddog Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 11-07-2001 01:09 PM
Limited slip diff stuff subz Engine 4 10-10-2001 01:30 AM
