Old 04-01-2004, 08:12 PM
godfathers10 godfathers10 is offline
fan removal?
i'm looking for advice on the best way to remove the fan/clutch from the water pump there is a 1 5/8" nut that screws onto the water pump i can't seem to find the way to loosen that. 94 f150 w inline 6. any advice is appreciated.
Old 04-01-2004, 09:45 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: fan removal?
okay don't take the serp belt off untill you get the big nut off those tools that hold the pulley never work. okay so the belts still on right?? put the wrench on it now smack the end of the wrench with a BFH(hammer) the impact will brake it loose with a couple smacks. the nut uses conventional threads so turn it cc. another way to get it off is use an air chisel if you got one. put the chisel on a corner of the nut and give it a little shot it'll spin right off. good luck!!
Old 04-05-2004, 06:58 PM
that worked perfect thanks for the advice. by the way the people at the auto stores had no idea what the special tools were.
radiator fan removal? teemsta Grand Cherokee | Grand Cherokee SRT8 2 07-26-2005 10:59 AM
94 Gnd Caravan A/c-heater Fan Removal BLUEFOX181 Caravan | Voyager 2 07-23-2005 12:18 AM
96 C1500 Fan Removal wrights35758 C/K 2 12-13-2004 10:26 PM
Help W Fan Removal people Engineering/ Technical 0 06-11-2004 11:18 PM
Need help fast! Fan removal!! i8ayellowcrayon S-10 4 02-14-2004 05:42 PM
