Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-23-2005, 07:31 PM
teemsta teemsta is offline
radiator fan removal?
can anyone tell me how to remove the fan from the waterpump pulley? in case i have to change the waterpump. i took apart the fan itself from the fan clutch. its attached by a nut shape to the pump. i tried turning it with a wrench but engine turns over.
Old 07-26-2005, 10:38 AM
JDPascal JDPascal is offline
Re: radiator fan removal?
Tools like these help
http://www.mytoolstore.com/kd/kdengi06.html
They are for "Fords" but thats the idea anyway....
JD
Old 07-26-2005, 10:59 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
teemsta,
I ussually wedge a long screw driver/tire iron between 2 of the bolts holding the water pump pulley on, then using a 1 7/16" wrench loosen the fan clutch assembly from the water pump.
NOTE: You might want to loosen these bolts to get more grip when using a screw driver or tire iron.
