Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 04-01-2004, 12:02 PM
M_Bowers M_Bowers is offline
Send a message via AIM to M_Bowers
R34 electronics
Hi, I was wondering a few things. I'm going to put a RB26DETT into a 240SX. I was wondering if I got the R34 and the ECU...what would I have to do to make the electronics work with it, because I heard that with the right electronics you can change traction control, from AWD to RWD and things like that. So with that in a 240SX what would I have to modify to make those options work?
Thanks again.
-Mark
Old 04-01-2004, 11:42 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
"because I heard that with the right electronics you can change traction control, from AWD to RWD and things like that."
That makes no sense! You would have to change the whole drive train, and the electronics. It would be too much money, let alone from an R34. Get a R32 drive train, they are cheaper, and its the same engine
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-04-2004, 01:14 PM
R34 GTR's Avatar
R34 GTR R34 GTR is offline
Tony,
I don't know why you got the patience to post an answer to these kinds of questions!!
Bet most of them are time wasters..
Old 04-04-2004, 02:07 PM
SkylineUSA's Avatar
Vincent,
I know
Its all good
By the way, hows the car? Have you got it back yet? Waiting to hear what you have to say about those GT-RSs.
Old 04-04-2004, 02:36 PM
R34 GTR's Avatar
Tony,
There will be another week or two delay as now I'm considering whether to go for the GT2835Spro which my tuner has told me about. More lag, but more power. He said they are a new variant of the 2835S whatever that is!
Sounds good, but then I have spent big money on getting all the visable pipes chromed and it'll be a shame if they never get used as the 2835 turbos are top mounted!
Anyway, my wheels (Volks CE28N in 10.5X19) that arrived:
Wanted SO3 tyres but supplier have told me they are replaced by the new RE050, which in turn replaces the old RE040 (stock tyres for R34 GTR).
Since they haven't been out that long, there isn't much info on them but I think they are below in comparasion to the SO3.
Old 04-04-2004, 04:45 PM
SkylineUSA's Avatar
More lag, thats not my bag, baby!
I will say those rims will look the kitty on your R34. 10.5" wide, holly cow pop, that is wide. I will give the R34 that, you can stuff a lot bigger tire under her.
Keep the GT-RSs, they will have more than enough power, as long as the engine is set up correctly.
Old 04-04-2004, 04:57 PM
R34 GTR's Avatar
I'm not too worried about lag, but just that if the RS won't make me satisfied, then I'll have to go bigger. So maybe just skip the RS now and go for the BIG power?? I haven't really heard any encouraging comments about them....
I'm getting some 285/30/19 tyres for the wheels. They are exactly the same diameter as the stocks, so meaning same rolling radius. Just hope I have chosen the correct offset of the wheels! But they are very LIGHT! Could really believe it.
How about your cars? I don't even know what you are doing/planning.
Did you go to Grasshopper today? Some new member brought their Murcielago and was giving rides.
Old 04-04-2004, 05:52 PM
SkylineUSA's Avatar
The RS is a lot bigger turbo than I would ever go after. They have a lot more top end power than the 2540, but they need to be married with the engine components, the key is setting it up correctly.
Who has told you that the GT-RS do not produce. Any turbo that requires you to increase your cc's, is going to push a lot of air. With that amount of volume, and the inevitable higher power band its going to produce some good numbers. I would think anything less than 272/10.X would cause bottle necking with those turbos. If one thing is over looked, the engine will not meets its potential. Meaning, maybe the other people you have talked to, did not set-up the engine correctly when using the GT-RSs.
What about drivabilty? To me, that is everything, I am not after a big rush after 5000rpms. I much prefer a usable power band, that is why I think you should stick with the GT-RS, rather than a more laggy GT2835Spro, IMHO.
My cars, will I am at an impasse. I just applied for a 3 year extension on my tour. So, my 393, T76 GTR is on hold until I find out if I am staying. My Black GTR is going to be modded, but I am opting for the GT-SS, but I plan on doing something a little different, for better drivability.
No Grasshopper, the wife went to Italy. I had to stay home and clean, and work on the cars. I would have loved to have gone, you don't see a Lambo every day
1973 el camino- electronic ignition. HELP Landmeier El Camino 3 04-14-2009 08:33 PM
AutomotiveForums.com R34 Nissan Skyline GT-R N1 RACECAR for sale on eBay igor@af General Discussion 0 04-10-2009 03:43 AM
For all you R34 fans, it seems that there are r34 kits for your r32 uranium235powered General Discussion 6 11-26-2004 04:19 PM
Does GT-R R34 parts fit GT-T R34? DemoX General Discussion 3 11-09-2004 02:10 AM
Differences between R34 GT-R and R34 V-Spec GTR-Power General Discussion 7 01-17-2004 11:43 AM
