Old 03-30-2004, 05:55 PM
daveshapellSVT's Avatar
daveshapellSVT daveshapellSVT is offline
Specvgini
track tips for my 99 cobra
Ok, i've been talking to ppl and i think i can run a 12.9 with my mods.. i'm just wondering what some tricks for the track might be? i've seen some guys remove there right headlight so they can get more air to the engine.. does that really help? how much? what about tire pressure? whats a good tire pressure to run on the rear tires? i have stock 99 cobra rims with nitto 555R drag radials.. how about weight? is it worth it to remove the spare and jack? anything else that will help? i wanna first try and run the 12.9 with the car just the way it is and if i can't get it i wanna use some tricks so your help and commentsare appreciated..
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
Old 03-30-2004, 06:35 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
get a set of slicks and hook hard. that's the best advice i can give.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 03-30-2004, 07:15 PM
Specvgini
Re: track tips for my 99 cobra
thanks, but will that break my rear end?
Old 03-30-2004, 07:20 PM
it might break your rear end, especially after repeated hard launches. but as your car gets more powerful, you're gonna have to upgrade that anyway. i mean, if you told me that's as far as you're ever gonna go with your mods i'd shoot myself in the foot. if i were you, i'd get a good diff, a pair of 31 or even 33 spline axles, c-clip elims, and a rear support. that wouldn't cost too overwhelmingly much, and carry you a lot farther. while you have the diff open you can also change wheel bearings, it's a good opportunity. and if you up your rear gear a little you'll be just that much faster, too.
-Andy
Old 03-30-2004, 11:33 PM
SikNingStang SikNingStang is offline
Send a message via AIM to SikNingStang
I would say 25lbs of air pressure would do good... 20 - 25... and removing the headlight gets more air in but it's like that ram air configuration whoever it was came up with... ram air is a myth I'd think the same thing applies here.
Theoredically every 100lbs you drop is the equivalent of gaining 10 hp... keep that in mind while removing stuff to lose weight... so a 2000lb car with 200hp should be even with a 3000lb car with 300hp... theoredically
Do you warm up your tires before launching? I found to be the best is just burning the tires till they begin to hook up and let off then run it... that seems to work best for me... I don't do any excessive burnout/white smoking everywhere. It doesn't seem to work as well.
That's about all I can think of... slicks would be good but... you got to get some first... lol
Old 03-31-2004, 04:59 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
#1 Any weight you can ditch do it! Rear seats, spare tire, jack, etc.., ditch it!!!
#2 Nitto DR's 18psi your gonna have to expirement a little but this is a good starting point.
#3 If you feel wheel-hop get off the gas right away!!!!!! That is how the half-shafts break. I have to be honest with DR's at a low psi like I said a few good launches could kill a half-shaft.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 03-31-2004, 02:57 PM
Specvgini
sweet i'll lower the air pressure to 20lbs, and i'll remove the spare and jack see how much that does... now, should i prep the tires at the track? heat them up by doing a burnout or is that just for slicks? i totally don't wanna take a chance at breaking anything, but i guess by going to the track i already am lol
Old 04-01-2004, 12:09 AM
drag radials... yes you should warm them up... you can tell the difference by simply driving through gravel... if you burnout you can hear them picking up all the little rocks but when they're not warm they won't... that's just an easy way to see that is DOES help them get sticky/stickier.
Old 04-01-2004, 12:10 AM
Specvgini
thanks man..
Old 04-01-2004, 11:15 PM
GrahamGT GrahamGT is offline
Not me, I don't know if it's just me but a spare tire has been a life saver many "A" time. I don't know what it is, I'm starting to think it has something to do with the burnout that last for a solid 30 seconds but I'm not sure. :continues thinking:
Old 04-03-2004, 05:24 PM
Specvgini
i may seem kinda fagish, but i really don't wanna get ahrdcore on gutting the car.. i think i'll go as far as the spare and jack, but interiors get ugly fast when you remove them alot..i used to do that in my 2000 Z24 and after a while there were scratches, tears, and parts that didn't fit.. It got me a 15.3 though let me tell ya lol hey is it true the track won't let you run without a roll cage if you run 11.9 or lower?
Fuel Economy Tips for a Jeep Wrangler 2009? wranglewithmyjeep Cars in General 0 01-13-2011 08:13 PM
Fifth Gear - Tiff Track Tips with Audi S3 trev0006 Car Videos 0 12-15-2006 03:43 PM
Road and Track GTO vs. Cobra RedLightning Modern GTO's (2004-2006) 1 07-13-2004 11:47 PM
Need a tip for my tips Suislide Car Modeling 9 01-07-2003 09:08 PM
I'm starting a focus site and need how to's and tech tips for tech tip section n1kki6 Focus | C Max 0 09-09-2002 02:01 PM
