Where is radiator drain plug?
I have a 97 Sable that has a leak in the plastic reservoir for the radiator. I've bought the new reservoir and now want to replace it and, while I'm at it drain and flush the radiator. My problem is I can't find the radiator drain plug/cockpit. Any suggestions?
Drain plug location
Hi there! I'm pretty sure that the drain plug is on the driver's side. Looking at my Sable there is an area that looks like a plug molded into the rad just behind the left-hand side of the transmission cooler. There is a plastic, white-coloured piece that faces downward (the plug, I suspect) and a little 'spout' that points toward the front of the car just infront and above that.
Hope this helps.
Re: Where is radiator drain plug?
Hello I have a 1999 mercury sable and I can not find the drain plug
can anyone help me with this problem, my wheel sounds like its rubbing against something I was told It could be my bearings on my car could this be the problem or is it something else
Removal
The radiator draincock is located near the bottom of the radiator. CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs, the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles. Turn the radiator draincock counterclockwise with a pair of needle nose pliers to unscrew. When the radiator draincock is unscrewed to the end of the threads, pull the stem from the radiator. Remove the radiator draincock from the radiator by squeezing the sides together with a pair of needle nose pliers. Then pull the radiator draincock from the radiator. Installation Make sure O-ring is in groove on stem of radiator draincock. Water-saturate radiator draincock in order to wet O-ring. Push the radiator draincock into the radiator opening until it snaps into place. Tighten the radiator draincock by turning clockwise to 1 Nm (8 inch lbs.). |
