Old 01-24-2004, 09:41 PM
decrepid decrepid is offline
radiator drain plug
I am going to flush my my engine and replace the coolant, but am having problems with the drain plug. I would like to use disconnecting the lower radiator hose as a last resort. the ploblem that I am having is the drain plug on the radiator. I am sure that I have found it, but am wondering if there is some special trick to getting it off/open. Thanx.
'94 Pontiac Grand Prix SE
3.1L V6
Old 01-24-2004, 09:52 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: radiator drain plug
The problem here is that if has been a while since the last time that you drain it, debri might have settled on the inner side and stuck it to the radiator. If you check on your AutoZone or Western Auto on the help section you will see that they sell those cocks. If you break getting it out just go get there a buy a new one. If I where you I would go there and get the replacement first...
Old 01-26-2004, 10:37 AM
JJUBECK JJUBECK is offline
Yeah there a bitch to get off, very little room for my big ass hands, I broke mine the first time, you can get them at autozone pretty cheap
Old 01-26-2004, 11:48 AM
fast98gtp's Avatar
fast98gtp fast98gtp is offline
Send a message via AIM to fast98gtp
there's no real trick.. i have to use pliers to twist it...it's a tight fit tho. iv messed with mine so much it's about to break
