Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 03-30-2004, 01:33 PM
Mistyk_1313's Avatar
Mistyk_1313 Mistyk_1313 is offline
Couple of questions..1990 Dodge Shadow
This is a first for me...When i get the car to around 40 KM/PH the engine sounds like it is running at 4000 rpm or higher (not straining just running high). But the display registers 2000 or so. It is an automatic transmission. Driving an 1990 Dodge Shadow. Any ideas?
Secondly, I am having an internmittent transmission issue when in drive. It usually happens after stopping at a light/stop sign and starting again, feels like it slips into neutral and back into drive on its own. Sometimes on an incline it will do the same thing. I have refilled the trans fluid which seems to have lessened the problem a little, but it is still happening.
Any help or suggestions would be great.
Thanks.
Old 04-01-2004, 05:33 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Let me guess, you have a 3.0L V6 in that car? If so that means you have the A-604 automatic as well. It sounds like your transmission needs a rebuild. I would get it to the dealer and have it looked at.
Old 04-01-2004, 05:56 PM
Actually it is a 2.2L 4 Cylinder...probably doesn't change anything though does it...
Old 04-02-2004, 09:38 AM
Polygon's Avatar
The Red Baron
Really?!
In that case you have an A-413, much better than the A-604. However, it still sounds like the tranny needs a rebuild. I would go to the junk yard and see if you can find another one with low mileage on it.
1990 Dodge Shadow Speedometer Not Working haroldj1701 General Discussion 0 08-31-2006 01:45 AM
1991 Dodge Shadow Fuel Injection Questions KManiac General Discussion 3 02-13-2006 09:05 AM
Question regarding Dodge Shadow (lol) rruddfan21 Metro 4 06-20-2005 03:51 PM
i have a few questions about my 94 dodge shadow that maybe someone could help me out nemo34 General Discussion 2 01-13-2004 05:30 PM
93 Dodge Shadow Fuse and General Speaker Questions Idiot General Discussion 1 09-24-2003 05:44 PM
