Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-28-2004, 02:53 PM
academygirl academygirl is offline
Unhappy Locked Ignition
The ignition on my 2001 Saturn SL1 is locked up. Drove it last night -- no problems (none prior to last night either). This afternoon, tried to start the car, the key will not turn in the ignition. Usually, this means that you simply need to turn the wheel slightly and the key will turn. Not this time! Any idea what the problem is, how solved?
Old 04-06-2004, 10:00 AM
Superman4611 Superman4611 is offline
Hey, I just recently bought a 1996 Saturn SL2. My ignition locks as well and I'm not able to turn they key but...it has an aftermarket alarm on it and it has to disengage the alarm before they key will turn in the ignition so make sure when you get in your saturn before you try to start it hit the unlock so all the doors are unlocked. It works for me not sure what's all going on with yours.
Billy
P.S. Hoped this helped.
Old 04-09-2004, 10:16 PM
malcolm brumley malcolm brumley is offline
Re: Locked Ignition
There is a cable that allows the ignition to turn only when the transmission is in park. You might try to move the shifter handle and see if it works.
macbrum
Old 07-23-2004, 05:41 PM
tiffen6 tiffen6 is offline
saturn SL1 (manual Trannie)
I have the same problem. It won't allow me to turn the ignition over. It has happened on 2 other occasions. When I let it set and come back it works. It has been two days now and It still hasn't allowed me to turn the ignition over. HELP!!
Thanks for any help I receive.
Old 07-24-2004, 12:59 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Locked Ignition
tiffen6, are you saying you have a no start condistion? because they are talking about not being able to remove the key. so are you saying you can't turn the key or the starter is not engageing?
assume you can turn the key -
do you hear any click or any engine noises?
when you turn the key does the radio cut off?
when you turn the key do any of the lights dim?
what year/model/mileage?
Old 09-16-2004, 12:07 PM
kendog23 kendog23 is offline
Re: Locked Ignition
Malcolm is right, make sure you are 100% in park.
Old 03-03-2005, 07:08 PM
1979Lee's Avatar
1979Lee 1979Lee is offline
Re: Locked Ignition
I have the very same problem with my 2002 SL-1
the key will not turn without great effort ,
it has been doing this for at least 2 years.
and its getting worse by the day .
help please
Old 03-11-2005, 07:29 PM
1979Lee's Avatar
Re: Re: Locked Ignition
help please
Any one have a way to fix this problem ?
Old 03-18-2005, 08:11 PM
1979Lee's Avatar
Re: Re: Re: Locked Ignition
Need Help With This Problem ,Does Anyone Know How Too Fix It?
Old 03-18-2005, 11:59 PM
Re: Locked Ignition
try the simple stuff frist, lube the key hole.
and also for some strange reason, cuting new keys sometimes fixes the problem(even out of bad ones)
2004 Steering/Ignition Lock Siezed ragg2 Rendezvous 0 01-05-2010 08:44 PM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
Steering wheel lock/Ignition switch/Car start problem 1983 320i zorq 3 Series 0 11-27-2005 12:52 AM
Locked ignition Switch Samantha2424 Cavalier Problem Diagnosis 4 10-16-2005 11:29 AM
Locked Ignition Cylinder 94 SL2 mrharris32 SC/SL/SW 2 03-15-2005 05:23 PM
