Old 10-15-2005, 08:08 PM
Samantha2424 Samantha2424 is offline
Locked ignition Switch
I went out to start my 1996 Pontiac Sunfire and found that I can put the key in the ignition but cannot turn the key...the ignition is locked. Does anyone know what I can do?
Old 10-16-2005, 02:11 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: Locked ignition Switch
WD-40 on your key and stick in in a few times. Let it sit. Repeat a few times. Try again.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 10-16-2005, 08:08 AM
Ignition switch locked
Thanks, I will try the WD40!
Old 10-16-2005, 08:51 AM
cdru's Avatar
cdru cdru is offline
Just make sure that graphite other other "powder" type lubricant wasn't used before. If it was, you will just make the situation worse.
Have you tried other keys, preferably lesser used keys, first? Over time, the primary key can wear down so that the peaks and valleys aren't quite where they should be. For the same reason, it's also possible that the pins in side the cylinder have worn down as well.
Vinyl adds horsepower, right?
Old 10-16-2005, 11:29 AM
Ignition Switch Locked
Well I tried the WD40 and it didn't work, but was a great suggestion, thanks! I will try another key and will talk to my husband about the pins. Thanks for that suggestion too!
