Old 03-24-2004, 07:47 PM
brianhsr brianhsr is offline
Send a message via MSN to brianhsr
rear deck speakers
the rear deck speakers in a 1998 grand am se a flush mounted, I can see
the screws in the trunk,but im not certain how to remove them.I dont think the back seat folds down,and there is a cover over the speakers
as well.Any tips? thanks
Old 03-27-2004, 10:18 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: rear deck speakers
Hi Brianhsr ,
Your rear seat backing does fold down , theres a strap in the trunk you pull to release the seat located near the speakers. Fold the seat down and there will be a plastic trim sorounding the edges of where the seat was , it is held on by push pins , remove the push pins to remove the trim peice. Then theres the rear deck cover , since the pins that hold the trim actually hold down the deck cover as well all you have to do is lift the front and pull and the cover comes off. The speakers may have simple snaps that you depress to remove them from the housing and a wire harness clip to remove the speakers from the deck. Hope that helps.
P.S. - dont touch that lil trunk light bulb , it burns instantly.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 12-18-2004, 04:59 PM
dougb2k1 dougb2k1 is offline
Wow this is a little old, but im having the same troubles with the same car. I cant find the release in the trunk. Any more help or pictures would be greatly appreciated.
Old 12-18-2004, 10:53 PM
justin0717 justin0717 is offline
your car is probably like mine and there is no release...there are three L type brackets near the top of the seat on the back that you will need to pry up to get the back of the seat off...then you can just push this down out of the way for now...and the cover over the speakers should come off with alittle force....then jsut unscrew the speakers...install the new ones...put the cover back on...then line the three brackets back up....and either have someone hold the seat back...or wedge something in there so it will stay pushed all the way towards the trunk...and then go and rebend the brackets back.
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
Old 12-19-2004, 12:15 AM
what a pain in the ass.
Old 12-19-2004, 08:12 AM
yea...if you have the fold down rear seats its a hell of a lot easier...as markgase2000 said.
Old 12-19-2004, 04:17 PM
swalt's Avatar
swalt swalt is offline
The 93's were the same way. Screwed in from the top which required the rear side panels and the rear trim deck to be removed just to get the speakers out. The speakers rested on the rear window deck. When I replaced the speakers I picked up so locking tabs from Home Depot and slid them over the holes and mounted the speakers from the trunk side instead. Figured it was much easier for the next time the speaker come out than wasting the hour dismantling all the trim in the back.
Old 12-19-2004, 05:32 PM
Well I had to pull the bottom seats up. unscrew the bolt holding both seatbelt locks, which also held a loop coming off the bottom of the back seats. That made it able to pull off the back seats. Then I had to remove half of the back trim to get the back cover off. after that it was pretty easy. I removed the factory speakers and installed my new(er) ones. I had to cut the plug off the speaker wire and tape together my plug things for my speakers. I wasnt sure what wires were + and - but I found a wiring diagram for the 2001's monsoon system. all the same colors were in my car so i figured it was worth a shot, so far so good.
Putting everything back together was a real pain in the ass. There are 3 push pins on each side of the top trim that sits on the rear deck cover. I broke one on each side removing them and broke another on the driver side while putting it on. Then lining up the bottom trim on the driver side was a pain in the ass but after dicking with it for a half hour in the freezing cold green bay weather, i finally got it. Then i put the seats back on and all was done.
Thanks Justin0717 for the help and insight. I really dont understand why pontiac made this such a pain in the ass to do. If they would have just made the speakers bottom mounted like a cavalier this would have been soo much easier.
help with removal of rear deck speakers. wichitacavi2002 Cavalier 2 10-31-2004 09:58 PM
Rear Deck Speakers? quikgtp Grand Prix 3 06-24-2004 06:26 PM
Rear Deck Speakers jmzjmz Car Audio 0 04-01-2003 03:10 PM
Rear deck speaker Andgo Audio/Security 11 04-22-2002 05:47 AM
Door & Rear Deck Speakers neverdat Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 02-09-2002 03:55 PM
