Old 03-23-2004, 03:27 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
ZC Swap??????????
Ok, i was goin to do a B18a1 swap, but i kind of need to hurry up and get my car back on the road, so money wont permit me to do the b series swap, So i have decided to go ZC, First off, i need to no whether or not there is a big power difference between the SOHC and the DOHC ZC. aslo i was wondering would i have to do my wiring for mpfi on the ZC the same way i would if i were doin it for an si. Also i was wondering if it takes the same axles as my stock ones, and if my si tranny that i already have will work on it. PLease get back with some info ASAP, I appreciate all help. and incase you dont know i have a 1990 Hatch STD.( with a blown engine now)
KoRnSaQ
Old 03-23-2004, 04:55 AM
dx_tuner's Avatar
dx_tuner dx_tuner is offline
I think the ZC is rated at 129Hp 106Trq. Yes, it will bolt up to your stock mounts and tranny. But I would recomend on getting new poly. mounts since your old ones are more than likely worn out. The wiring is the same as going from DPFI to MPFI except the crank angle sensor is at the end of the cam and you'll need to run 2 wires to that. Heres a nice DPFI to MPFI How to http://www.fourthgenhatch.com/mpfi.html
1989 Honda Civic HB DOHC VTEC 1.8L 07 2005
WWW.HONDA-TECH.COM
Old 03-23-2004, 06:22 AM
SiZ's Avatar
SiZ SiZ is offline
Re: ZC Swap??????????
Get DOHC at least!
"The nympho of info, I'm fuckin' what ya heard"
Old 03-23-2004, 10:14 AM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
you can get the longblock/zc tranny for 850 shipped from Hmotorsonline.com i have it in my car get the DOHC it's easy to put in it took me 3 days to get it in and running. if you have the std you're going to need the steering knuckle/hub from a dx or si because the std. won't work.
Old 03-23-2004, 01:07 PM
lilol89crx lilol89crx is offline
someone posted somewhere about sohc zc delivered for under 500. ive drivin the dohc as well as the sohc zc and the dohc has way better off the line punch imo but the sohc pulls way to redline stronger. for the price id settle for a sohc zc
Old 03-23-2004, 01:16 PM
Carnivore's Avatar
Carnivore Carnivore is offline
Send a message via AIM to Carnivore
i agree with Siz, don't get the SOHC ZC, go for the DOHC. You want an engine that can breath better and the Dohc breathes a lot better than the sohc, plus its looks better and quicker(stock)
I love my honda...I hate my honda
Old 03-23-2004, 02:03 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
looks better...lol - that's a new one...but yeah..that bitch fills up the engine bay a lot nicer
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 03-23-2004, 02:23 PM
90hbsleepr 90hbsleepr is offline
I got a SOHC ZC shipped to me door for $460.
Old 03-23-2004, 02:44 PM
Hybrid1990crx's Avatar
Man get the DOHC. But just get a long block. Use your Si tranny, its geared better.
Old 03-23-2004, 02:50 PM
Re: Re: ZC Swap??????????
I thought the std and dx knuckle/hubs were the same, and the si were different, but anyway which axles do i use, which ecu would be the best to use and which distributer do i get for it. The main thing i am worried about is not getting the engine in, cause i have done a swap before in my boys crx si, the main thing i have a problem with is the wiring, If someone can give me some in debth tips on the wiring that the mpfi how to may not tell me i would greatly appreciate it.
KoRnSaQ
Old 03-23-2004, 05:11 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Youll need axles and hubs from an Si (unless you keep your std tranny ) Because those are bigger and the std ones wont fit into a dx or si tranny. As for the wiring, here are a couple links to help you out.
http://hybrid2.honda-perf.org/tech/4gdxtozc.html
http://www.zcspeed.com/wiring.htm
http://www.westworld.com/~joe_r/4gdxtozc.html
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-23-2004, 05:23 PM
the std hubs/ knuckles are 23 or 26 and the dx/si are which ever the std isn't i think the dx/si are 26 spline. they're larger too. if you're keeping the SI motor just use dx/si axels if you're using the ZC tranny (Make sure to get the intermediate shaft) use two (2) 91-93 integra right axels. I used the website www.fourthgenhatch.com for my wiring look under the howto section. it takes like 2 hours to wire the entire things. don't get scared by it.
what state are you in?
Old 03-24-2004, 03:13 AM
Actually the 90-91 spline count on the knuckles are the same for the dx si and std, because it was this time last year I put a si tranny from a 91 si crx in my car and did not have to change knuckles/hubs, it fit perfectly.
But thanks for the info especially about the wiring cause that has been the thing that has SCARED me about the swap.
Any other comment or tips are greatly appreciated
KoRnSaQ
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
ATT: Skyline240 or anyone doing the RB swap or anyone having info on the RB swap... dohctor_yaj 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 29 04-18-2003 09:55 AM
people who did the det swap or any swap - what did u do with the stock engine? jared240sx 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 09-19-2002 11:20 AM
Brake swap -is mandatory a Master Cyl swap? mmasse '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 05-25-2002 12:04 PM
Swap this Swap that..... white97ex Engineering/ Technical 8 01-19-2002 12:06 AM
