Old 03-21-2004, 10:35 PM
turbo93impreza turbo93impreza is offline
Question D15 block D16 head = what compression?
I have an 89 dx with the d15b2 and i'm considering swapping the heads from a d16y8 or z6 onto it and going vtec.
What compression will this bring?
higher or lower?
Old 03-22-2004, 05:08 AM
91civicDXdude's Avatar
Re: D15 block D16 head = what compression?
higher. depending on what head gasket and which head you use, you will most likely be in the high 9's or low 10s compression wise (9.8:1 or 10.2:1 etc.)
Old 03-22-2004, 12:37 PM
d16a6crx's Avatar
d16a6crx d16a6crx is offline
here just use this.. you plug in different heads, blocks, pistons, etc and it will give you the compression yeilded
http://www.knology.net/~jediklc/D.htm
d15b7 with Z6 = 9.8:1
d15b7 with Y8 = 10.2:1
1991 CRX Si
Looking for 88-91 Sedan or Hatch
Old 03-22-2004, 05:05 PM
are there any heads, preforably vtec that will lower compression? or can i double the headgaskets up or something?
Old 03-22-2004, 05:37 PM
d16a6crx's Avatar
Re: Re: D15 block D16 head = what compression?
There aren't any VTEC heads that will lower compression, but if you use d16y8 pistons with a VTEC head, the compression would not be so high...
d15b7 block w/ Y8 VTEC head & Y8 Pistons = 9.0:1
" " " Z6 Pistons = 8.3:1
1991 CRX Si
Old 03-22-2004, 08:05 PM
has anybody heard of doubleing up the head gaskets on hondas? (have heard of it elsewhere).
Old 03-23-2004, 08:53 AM
d16a6crx's Avatar
Personally i havent heard of it, but even if you can do it, it won't lower compression much at all...
d15 w/ d16y8 head, double head gasket = 9.5:1
What kind of compression are you looking for?
1991 CRX Si
Old 03-23-2004, 05:16 PM
low enough for a little turbo action, 9.5 is ok but 9 is better
Old 03-23-2004, 05:51 PM
d16a6crx's Avatar
like i said, d15b7 (should be close to d15b2) with y8 head and pistons yeilds 9.0:1 compression
1991 CRX Si
Old 03-24-2004, 08:29 AM
unfortunatly i also dont have the means to swap pistons.
Old 03-24-2004, 10:53 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
you dont have the means to swap pistons, but you are goin to turbo it
KoRnSaQ
Old 03-24-2004, 12:36 PM
d16a6crx's Avatar
Re: Re: Re: D15 block D16 head = what compression?
Yes, if youa are going to turbo it, you will need to swap in aftermarket pistons and rods if you plan on running anything more than 6-8psi for a period of time. Should be fine with 9.5:1 compression still with a turbo
1991 CRX Si
Old 03-29-2004, 04:44 PM
what heads are on the 88-91 crx si? i found one of those motors and i could pull that head, but i would like to know the compression afterwards.
Old 03-29-2004, 06:31 PM
d16a6crx's Avatar
they have a d16a6
1991 CRX Si
What metal is the engine made from? robgilbert Aveo 10 08-01-2010 11:46 PM
K&W block sealer after failed head swap Bob9646 Thunderbird 4 07-19-2009 09:33 PM
D15 Bottom D16 Head CREXSI '71-'87 Civic | CRX 6 12-19-2005 06:36 PM
350 block 305 head, what size intake manifold? dmbrisket 51 General Discussion 0 05-03-2005 03:53 PM
D15 block with D16 head? Possible? mdnnccivicrcr '88 - '91 Civic | CRX | Wagon | Shuttlee 1 07-17-2002 01:57 AM
