Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-21-2004, 09:12 AM
WickdZ's Avatar
WickdZ WickdZ is offline
1988 V6 idle problem
Hey guys (and gals),
I am new here and really like this site. I do have a question for ya'll. I just bought an 88 Dakota with the 3.9 V6. It runs great, except for at idle.
I have replaced: cap and rotor, plugs and wires, PVC valve, fuel filter, and the air filter. I bought a Haynes manual and checked the EGR operation per the book, and it checks out fine. Also set the timing to 10* BTDC. I searched the forums and can not find the same problem.
What else should I check for? I have an Auto Xray, but there is no port to plug into. I check for codes and the computer did not have any.
Help!
Thanks, Thomas
Old 05-02-2004, 02:01 PM
5spd 5spd is offline
Re: 1988 V6 idle problem
Check IAC or stepper motor
Old 05-02-2004, 10:43 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Yeah IAC valve or throttle position sensor is what I would replace.
Old 05-03-2004, 12:34 PM
slantsixness's Avatar
slantsixness slantsixness is offline
IAC, TPS, Stepper, O2 sensor.
Vacuum leak.
At least One of them!
No codes? Are you sure? Did you get 5/5?
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 05-03-2004, 10:27 PM
BleedDodge's Avatar
That's a 1988 truck though. Did OBDII go that far back? I thought the key code thing began only as far back as 1996?
Old 05-04-2004, 02:13 PM
88 sure has OBDII if fuel injected . At least I know for sure '89 did and full size trucks did '88-on with FI and 3.9/5.2/5.9 L engines.
Mopars have had the computer codes and the same way of checking them as far back as '87 that I'm sure of, on the 2.2/2.5L and Caravans. Trucks had to wait for FI first, I think maybe that was '87? My '86 has a SMEC, but doesn't do the flashes...
But hey, I could be wrong!, or the '88 could have been made in Mexico with used '72 Dart parts like the Ramchargers...! (Ok,... I owned one... that's not funny....!)
Slantsixness
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
Corona 1988 Idling problems marciusvz Corona/Caldina/Carnia 1 07-28-2007 10:54 PM
