Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 03-20-2004, 09:12 PM
jmoffit jmoffit is offline
Question coolant odor when warmed up
on my 1999 pontiac montana after driving a short time and van warms up when exiting vehicle i smell coolant,vehicle temp gauge shows normal temp,however coolant needs to be added frequently,there is no coolant in oil or oil in coolant,any suggestions will be appreciated!
Old 03-28-2004, 03:16 PM
gord7 gord7 is offline
Re: coolant odor when warmed up
Sounds like a gasket problem, check to see if there is any coolant leaking down from the head gaskets and dropping on to the exhuast manifold. A fairly common problem in the vans.
Old 04-07-2004, 12:52 AM
jay hullett jay hullett is offline
might say all gm cars and trucks will develope coolant leaks at intake gaskets r plastic and crack they will leak to outside but if not repaired will lead to water in oil 3.1-3.4-4.3 5.0-5.7 etc
Old 04-12-2004, 09:52 AM
tmorris1 tmorris1 is offline
I recently had this happen on my 98 Montana. I couldn't figure out where the coolant was going, the oil looked good etc. One day my wife said the belt was squealing, so I went to check it out expecting to just replace the belt since it had 89,000 miles on it. There was antifeeze all the belt which got slung (is that a word?) all over under the hood. It turns out the water pump was leaking. I suspect it was only leaking a little, and after I had a coolant flush it dislodged some crap and it leaked like a sieve. The water pump is completely consealed behind the pulley, so you won't notice a problem until it leaks a lot. Put you finger under the water pump pulley and see if it is wet.
The dealer wanted $230 to fix, but I did it myself for $30. $23 for the pump (lifetime warranty) and $7 for coolant. Took me a couple hours, and I am not exactly Mr. Goodwrench. Cleaned up under the hood with a hose, checked for leaks and it now runs great. It will take a while to get rid of the antifreeze smell. That stuff is nasty.
Old 05-18-2004, 06:07 AM
czgu czgu is offline
I had same problem. It could cost you $700 - $1000 to fix gasket problem. I called GM Pontiac. Finally I got dealer warrenty (I don't know what was the deal between GM pontiac and the dealer).
Old 05-24-2004, 02:16 PM
DamienZ28's Avatar
DamienZ28 DamienZ28 is offline
Same problem I have a montana and a alero same engine same problem...
http://www.fiawtcc.com/
2006 BMW 330i| 2009 Mercury Mariner Premier
HELP! 92 Ranger doesn't want to move when warm!! fordstranger Ranger | Courier 3 07-16-2009 07:33 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
Slight coolant odor kmohr3 Intrigue 2 10-29-2006 07:35 AM
Coolant odor in cab red180s S-10 8 11-19-2005 06:46 PM
99 Jeep Grand Cherokee, Musty Odor When Heat Is On? legan Grand Cherokee | Grand Cherokee SRT8 5 12-21-2004 08:45 AM
