Old 11-13-2005, 06:44 PM
red180s red180s is offline
Coolant odor in cab
I have a 99 4.3. The past few days I have noticed a strong coolant odor inside the cab of the truck after I drive it for a few minutes. There is no coolant in the oil and the appears to be no noticeable lowering of the coolant level. As well, There is no loss in power and the heater works fine, the engine temp stays at operating range without fluctuation. There are no leaks in the hoses that I can find either. I am stumped as to the cause and would apreciate any help.
Old 11-13-2005, 08:10 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Coolant odor in cab
Heater core maybe?
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 11-14-2005, 07:04 AM
dugie6551's Avatar
dugie6551 dugie6551 is offline
Yeah, it's the heater core.
Check the passenger side floor area. When a heater core breaks it will leak into the cab area on the passenger side.
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
Old 11-14-2005, 08:45 AM
khregg khregg is offline
yep, definitely the heater core....happened to my 94 a few years ago....your windows probably get foggy and filmy a little as well if the leak is bad enough.
Old 11-15-2005, 06:18 PM
Thanks, I will check it out. The windows have been getting foggy and the leak is getting worse. Does anyone know how difficult the heater core is to change? Thanks.
Old 11-16-2005, 12:47 PM
rustbucket rustbucket is offline
A few hours. Here is a link that may help:
http://www.sytyarchives.com/howto/vi...imate_controls
If you decide to only loosen the dash and pull out the right side, dont let it hang there without support. It puts too much stress on the surface and it will will crack.
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
Old 11-17-2005, 02:49 PM
dmunsey dmunsey is offline
Re: Re: Coolant odor in cab
I had the same problem with my 87 Ranger,wasnt real hard on it to change the core. Good luck
Old 11-19-2005, 10:32 AM
2001_CrewCab 2001_CrewCab is offline
There have been numerous accounts of this type of problem. First, do you hear a "gurgling" sound coming from behind the dash? If you do now, or hear it later, it means your heater core is about to go. Within a month, the sound will cease, and your cab will fill up with that pleasant smelling steam. Some believe that the orange dex-cool radiatior coolant is the culprit since this is a case that has happened to very many people, but nothing is confirmed as far as I know. So if you hear a "gurgling" coming from your truck at any time, go ahead and buy a heater core...you'll need it soon.
Old 11-19-2005, 06:46 PM
wafrederick wafrederick is offline
Banned
The dash has come out completely and it is a pain in the butt.Disconnect the battery,you do not want the airbag blowing out.
