Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-20-2004, 01:01 AM
ogparjay ogparjay is offline
Unhappy steering
i have problems with my alignment, it veers left... i got an alignment several times but it's still messed up.... depending on road conditions the wheel might be straight therefore my car goes straight but like on angle roads or on straights the wheel is tilted.... and it feels that my turns are not as responsive..... what can cause a bad alignment besides installing new lower springs?
Old 08-30-2004, 01:51 PM
havic havic is offline
Re: steering
Sorry for bringing up an old thread, but I'm having the same problem. However, I didn't get lowering springs. The steering feels loose and when the rod is at an angle so is the steering wheel, even though I may be going straight. When I turn to the left, the steering is slightly to the left when I finish the turn and the wheels are straight. Same thing with the right turns. My mechanic says the tire rods are fine, and he replaced the bushings, I forgot which ones because it was 6 months ago. What else do I need to check/replace? Also, I get a creaking sound when I turn the wheel either way. Any help would be appreciated.
Old 08-30-2004, 10:27 PM
rule da road rule da road is offline
Send a message via AIM to rule da road
Re: steering
do y'all have a tire gauge and make sure the pressure is up? for 17's u should be runnin close to 44psi. Check tirerack details for ur max pressure. this'll affect performance dreadfully.
Old 09-01-2004, 01:35 PM
Re: steering
Tire pressure was even all around and up to spec (I have factory rims).
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
Difference between a '94 and '95 steering column? Steering column guard.. telepunk Trans Sport 1 01-18-2005 01:14 PM
Loose Steering wheel/ Steering Slop & Tranny P1870 pkspx01 Blazer 10 11-02-2004 03:30 PM
Power steering steers hard to the left Grayl in Phx Aurora 5 01-19-2004 02:49 AM
Steering Wheel Or No Steering Wheel CivicLx Car Audio 8 01-25-2002 03:02 AM
