next hp boost?
I (obviously) have an 88 5.0L v8 t-bird that i want to make faster. I haven't done much to it except rebuild the tranny and put intake and glasspacks on it. My dad says i should put a pair of injectors on it next and my friend says a new throttle body. I don't have much money so i need input as far as what will be cheap and effective.
Thanx |
Re: next hp boost?
One won't help that much with out the other you really are going to need both for the other to do its best.
I understand what you're saying, but i was looking for suggestions on top of those already given. Eventually, i wanted to completely rebuild the engine with all aftermarket parts, but hopefully you can understand that i don't have the money for that. I have about 1200 dollars stashed away and i was looking to buy a supercharger and later my dream is to convert the car from an automatic to manual tranny. I was kind of asking if there was anything else i could do to the car that would give a decent boost to horsepower for cheap other than what i had mentioned.
Thanks for any further input |
Re: next hp boost?
Get some headers and open up the rest of the exhaust to at least 2 1/2, if you can. At least cat back. Keep in mind that whatever you do to the engine itself (heads, intake manifold, cam, injectors, MAF, TB, etc.) you may have to redo it all once you are ready for the blower. For a blower, you should be around an 8.5:1 compression ratio, higher (9.5-10.0) if you keep it NA. Not sure what you mean by intake. Plumbing, larger MAF & TB, or the manifold itself? Get a cold air intake or make one yourself. Get rid of the fan and put an electric one on there. You may want an underdrive pulley set. If you can get rid of the air pump, do that. Emissions may be a concern for you so keep that in mind. Rear gears would not be a bad idea, either.
It's not how fast you can go, it's how fast you can get there. Proper grammar, it's not just for English teachers. I don't pick on any one person, I treat everyone this way. My only pleasure is tormenting those people who work for me. There are no stupid questions, just a lot of inquisitive idiots. |
Re: next hp boost?
Awesome, thanks a bunch: by intake i meant i replaced the factory filter with a superflow cone filter. Nothing extravagent
Re: next hp boost?
well.. how about convert it from its non HO to a roller camshaft high output 302? Can be done with parts from a Mustang GT in the junk yard.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
