Old 03-18-2004, 10:13 AM
plant plant is offline
Question Rattaling noises on every bump
I bought my 2000 2door ZR2 blazer a year ago with 44000 miles on it. Ever since I've had it it makes all kinds of rattling and creaking noises on any road imperfection. I think it is coming from the interior panels but I'm not to sure also I think it once had an aftermarket radio removed? any suggestions it very annoying
Old 03-18-2004, 02:23 PM
doc13ryde doc13ryde is offline
Send a message via AIM to doc13ryde Send a message via Yahoo to doc13ryde
I might can help or someone else might can if you can listen and tell exactly where o around where they are coming from
Old 03-19-2004, 09:57 AM
Re: Rattaling noises on every bump
It is coming from mainly from the passenger rear panel area just below the window area and also from the tailgate window area.
It is a 2 door 2000 ZR2 blazer. I'm also not sure how to properly remove the rear interior panels.I can get the door panels off but the backs seem different. thanks for any help you can offer
Old 04-20-2004, 04:43 AM
tonsofunburns tonsofunburns is offline
Send a message via AIM to tonsofunburns Send a message via Yahoo to tonsofunburns
Most blazers have the problem with the rear window striker. check the striker for wear. A cheap and temporary fix would be to put duck tape on it but you can replace the striker plate for under $20. As for the passenger door it is probably the clips holding the panel on the door. They break very easily when removed.
LS making front end noise over bumps trinah1 LS | MKZ 65 04-03-2021 04:10 PM
Metal noise when bump (sometimes) SUPER KING Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 05-31-2008 11:39 PM
HELP!!!Colorado sqeaks on every bump wesson123970 Colorado 2 09-11-2007 11:58 AM
noise over bumps terpsfan88 Thunderbird 12 01-31-2007 08:54 PM
2000 ZR2 rattaling noises on every bump plant Blazer 8 02-01-2005 01:38 PM
