noise over bumps
93 super coupe
when i turn sometimes and go over bumps the car makes a creaking sound, i thought it might be struts. any one help |
Check the ball joints & strut rod bushings.
sway bar links, ball joints most likely
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING. |
Re: noise over bumps
just replace every bushing and ball joint under the front end. I havent done mine yet but i will soon.
noise over bumps
mine did the same thing but mine was the hub and no i did not get the humming sound only a bad creaking when the wheels turned... struts will creek also, so would be a good idea to get them both checked out alot of places will give u a free est. on chasis parts.
yea mine clunks over bumps on the passenger side. sqeeks and sqeels over bumps and while i turn on both sides. Its very embarassing to drive
Whenever I turn my wheel left or right doesn't matter when I'm putting on the brake or not, this squeeking groaning (not like power steering) occurs and it is really embarassing. Also whenever I push up and down on the strut it does a similar sound but I don't think that the problem I am having is the strut, it sounds more serious. Please help will be greatly appreciated. |
Check everything in the front end, have a listen to it while someone else turns the wheel. Grease everything that has a fitting on it.
Mine was really bad- it was the assembly brackets, cheap to replace now
nothing rattles at all
Mine used to make a popping noise. I found 2 bolts loose that hold the whole subframe to the rest of the car. Tightended them up and the noise was gone.
Two years ago on our '88, I found a broken spring--a hairline crack. The springs on these cars sit in place with a crescent type shape due to the suspension design. I'm sure its the same on a 90s. I believe they are prone to breaking due to the side pressures on them. A definite possiblility for noise. Check the springs--13 year old car puts the springs in old age at this point.
