Old 03-13-2004, 11:51 AM
plant plant is offline
Question 2000 Bkazer ZR2 rattaling noises on every bump
I bought my blazer a year ago with 44000 miles on it. Ever since I've had it it makes all kinds of rattling and creaking noises on any road imperfection. I think it is coming from the interior panels but I'm not to sure also I think it once had an aftermarket radio removed? any suggestions it very annoying
P.S. This is a great web site
Old 03-13-2004, 04:48 PM
keithk23 keithk23 is offline
I've had the same problem w/ my 2-door '01 Blazer. They claimed it was the spare tire on the back shifting around, but after "fixing" it, I have the same problem. Appears to be the area around the passenger rear window. I have asked several dealerships to look at this problem and they all blow it off. Over-all, ownership of this vehicle has severely impacted my STRONG impression of Chevy vehicles. If anyone has any ideas/solutions, I would be very greatful!
Old 03-13-2004, 05:17 PM
Re: 2000 ZR2 rattaling noises on every bump
A friend told me the bushing on the ouside spare was probably broke considering it made of plastic but the noise does come mainly from the same area as yours. I used the soft part of velcro tape to line the inside panels expecially the powerlock/window contols which helped a little but it really pisses me off still.
Does anyone know how to remove all interior body panels without breaking them? I think some stuff must be loose under them. Any help would be greatly apreciated
Old 03-13-2004, 06:27 PM
If you haven't had your spare checked out, it might be worth a shot for SOME improvement... supposedly the glass and tire mount were not alligned properly. Such a wonderful design they on this!
Old 03-14-2004, 12:45 AM
4WheelJunkie 4WheelJunkie is offline
My 2000 Blazer does this too. My fix is to turn up the radio a little bit. With my Blazer I hear it from the rear, almost like the glass is rattling or the spare tire is vibrating somehow. It is possible that the squeak is coming from the rubber boot that comes into contact with the tail gate when you close the spare tire arm. Who knows, it can come from anywhere in the back end of the vehicle. Just turn up your radio a little bit.
Old 03-14-2004, 12:15 PM
Denali Denali is offline
I had the same problems on my 98 Blazer. After several hours of work itīs now almost rattlefree. The worst rattles came from an Instrument Panel holder behind the cluster. After applying some grease itīs gone. The next is where the front doorpanels are touching the metal part of the door. Here I used Armor All between this. By the way: Armor All is very good stuff for rattling and creaking Interior Parts. Just spray the areas where panels are mounted to each other...
Old 03-17-2004, 08:59 AM
Thanks for the help.My blazer is a 2door and the rattling comes mainly from the rear panels by the speaker and rear window. It almost sounds like the rear window is rattling on the passenger side(the radio is off when it rattles). Any suggestions on how to remove the panels without cracking them or what to tighten or grease once I do get them off.
Thanks again for the input.
Old 02-01-2005, 01:18 PM
BigWoods BigWoods is offline
My 2000 ZR2 squeeks also. Check your speaker grills in the rear. Thats where mine was squeeking. Good luck.
Old 02-01-2005, 01:38 PM
swalt's Avatar
swalt swalt is offline
Rattles seem to be the norm for these trucks. One dealer told me if I wanted a quiet car, I should have bought a Cadillac.."you bought a truck, you can't expect it to run smooth." Needless to say, I have not returned.
The obvious rattles on these vehicles include the hood hinge rattle (do a search to see how to fix it) and the other being the rear lift glass where the striker on the window hits the latch plate. Sometimes you need to adjust the rear window handle (loosen the two bolts and re-align) to stop the plate from rubbing. If you look at the striker plate on the window, you will probably see a metal mark where it is rubbing. Keep the weather stripping flexible with silicone spray, and as one of the other posts mentioned, Armour All works great on plastic on plastic contact. I use quite a bit of Armour All (sprayed right on the panels) when I clean the interior, and I have very few squeaks. Two way tape/weather stripping also works well if you stick it behind any areas where there is plastic on metal rattles.
