Old 03-17-2004, 05:25 PM
gwayne100 gwayne100 is offline
relay switch 93 cavalier
I have a 93 cavalier. The turns signals started flashing fast, then stopped working alltogether. I changed all light bulbs, still won't work. I changed the flasher, still won't work. The emergency flashers do work. This would lead me to believe its a relay switch problem. Anyone know how to tear the steering console cover apart so I can replace the relay switch? I tried taking it apart, but it started breaking. So to avoid the wrath of my wife, I stopped & decided to ask for help. So, help!!!
Old 08-27-2004, 11:09 PM
integra_3682 integra_3682 is offline
Send a message via Yahoo to integra_3682
Re: relay switch 93 cavalier
I also have a red 93 chevy cavalier and it still is running strong. Also, I am having almost the exact same problem but it is the head lights that wont stay on and the high beams only work. I also checked the fuses and the light bulbs and found nothing wrong with that also. Then I found out that it was the combonation switch. But all my turning signals work. So maybe we can help each other because we have the same cars.
E-mail me back at [email protected]
hope to hear from you.
Old 08-28-2004, 03:07 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
you access the turn signal switch assembly by removing the steering wheel and lock plate assembly. both require special tools that you should be able to borrow from autozone( you pay a deposit and get it back when you return the tool undamaged) but are easy todo. Get yourself a haynes manual, and it will walk you through the proceedure.
1995 Econoline 350 relay switch?? David A Walker Econoline 2 06-30-2014 07:54 PM
2001 Cavalier is there a Fan Relay switch? buzzman Cavalier Problem Diagnosis 8 08-10-2013 06:09 AM
How do I make a " momentary switch " work like a continuous-current switch? LieutenantCracker Engineering/ Technical 7 01-30-2010 10:20 AM
1998 cavalier drl relay switch dcwack Cavalier Problem Diagnosis 1 10-19-2009 09:13 AM
How do I change my a\c relay switch on my 2000 cavalier? Tweakshill Cavalier Problem Diagnosis 0 06-07-2007 04:46 PM
