Old 10-16-2009, 09:52 AM
dcwack dcwack is offline
1998 cavalier drl relay switch
Where would I find the drl relay switch on a 1998 chevrolet cavalier?
Old 10-19-2009, 09:13 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: 1998 cavalier drl relay switch
the drl relay is in your fusebox, if you want to disable your DRLs simply pulling the relay out wont work. it will have some side effects on your normal headlights. you need to pull the relay out, then put a jumper wire in place of it. that jumper wire goes in 2 of the 5 slots the relay went into. i dont remember but if youre motivated enough im sure you can find out which ones
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
