95 buick uses oil
95 buick uses 2+ quarts of oil in 30-40 miles. there's no smoke, wipe the tail pipe and it's clean. can't see a leak from underneath. runs like normal
Re: 95 buick uses oil
To burn that mauch oil without a visible leak or smoke is really hard to believe but if you have no leaks then its burning the oil. Your engine had a problem with valve stem seals and GM came out with new seals.
The oil has to be going somewhere either is running out the engine or burning it!
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
