Old 03-16-2004, 08:57 PM
bclipse bclipse is offline
Eclipse problem need help please
i having trouble with my car it seems to idle fine then starts to die. Sometimes when its idling ill give it gas and it will sputter till it gets over about 2G then its fine over 2G. Im guessing im not getting enough air while in idle and thats y its idling bad. Could this be it. I need help. PLease give me an answer.
Old 03-16-2004, 09:07 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
it would help if you told us about your car... like what model you have... any mods that you have done to it... sounds like you have a vacuum leak but please let us know what you have got!
Old 03-16-2004, 11:28 PM
skyllz skyllz is offline
Re: Eclipse problem need help please
I had this problem. Replaced the ECU.
Old 03-17-2004, 08:06 AM
reply
its a 95 elipse gst. i thinking its a vacum leak to and i have another ECU so i might try that too. IF you have anymore replys please help me thanks
Old 03-17-2004, 08:07 AM
oh and its stock
Old 03-17-2004, 08:08 AM
kjewer1 kjewer1 is offline
AF - Advisor
Go to www.vfaq.com and make the intake leak tester. You'll find any and all vac/boost leaks if you do this. Well worth it, and everyone with a DSM should be doing this test regularly for the many reasons I've posted a thousand times in the past...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-17-2004, 06:12 PM
hey guys i ve been looking at my car and i noticed that the mass air flow meter wires were not the same. Looks like the guy i bought it from swapped out the air flow meter from a later eclipse and just connected wires to each other. if you have a airflow meter with the connections to it for a 95' GST please let me know
big problem need help!! please help s10man92 Problem Diagnosis 3 06-10-2009 10:53 AM
89 Plymouth Sundance Stalling Problems. Need help PLEASE! rancid General Discussion 13 12-14-2004 01:48 PM
S-10 Problem NEED HELP PLEASE keramed Engineering/ Technical 3 10-12-2004 11:58 AM
Eclipse Auto Tranny Problems **Need Help Please** 19eclipse97 Off-Topic 4 09-09-2004 05:44 PM
Electrical Problem...Need Help Please UNCG_Spartan 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 01-13-2004 08:56 PM
