Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-15-2004, 08:57 PM
Randydislikesford Randydislikesford is offline
Help!! Transmission powershifts
Help! Transmission powershifts in all gears, Scan says... EPC pressure jumps to 120% even shows pressure @ idle. Ford says " Not sure, but you need a new Tranny" Thanks alot Ford
Never any codes! (2 complete scans) Went to a local guy, he replaced EPC solenoid, filter, oil, body gasket, he worked for hours, even checked under engine for any ground shorts, he's stumped!
Thinks maybe it's in the computer control...didn't want to spend any more of my money. It not getting any worst in last 3 months ... any ideas... and THANK YOU!! Shall i still drive it till it dies? Drives me crazy!
Old 03-15-2004, 11:40 PM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Re: Help!! Transmission powershifts
What year? Engine size? You say EPC is 120. Is that amps? Pressure? Desired amps? OD light flashing?
Old 03-16-2004, 07:40 PM
Thanks Rex, 2000 ford explorer Limited, All wheel drive, 5.0L EFI V8, on the ford service receipt it states *"Transmission diagnostics EPC pressure jumps to 120% indicates internal problem possible forward clutch"*, not sure of amps, The local trans guy, did extensive amp check by hand and found no problems. OD light is not on.
Old 03-17-2004, 01:05 AM
RexNfx400's Avatar
It seems strange that there is no codes. If the computer sees anything out of range it should go limp mode, which is reverse and 2nd gear only. The transmission needs to be shifted with a shift box(that means with no input from the vehicle computer).Then someone would know if its inside transmission or outside(electrical). If EPC is 120 lbs then either the vehicle computer system is commanding it(accidentally, as max EPC commanded is 98Lbs) or there is a problem with the valve body(worn bore, blown gasket, broken springs, also an EPC solenoid can be defective right out of the box). The computer does not command high EPC because of a leaky forward clutch. This transmission is not adaptive.
I think the best thing to do is find a shop with a "TransX 2000" shift box. Or a "schaffer shifter" will do the job if they don't have the other. But, make sure they have one of these or don't even bother talking with them.
Also driving the car with harsh shifts caused by high oil pressure is very bad because it takes oil from the lubrication side of the trans. There is a balance of apply pressure and lube pressure. Take more of one and you have less of the other, basically.
Good luck!
Old 06-28-2004, 08:46 PM
homie774899 homie774899 is offline
Re: Re: Help!! Transmission powershifts
Hi My Name Is Rick... I Was Wondering If You Could Help Me With A Question I Have....... My 94 Explorer Will Struggle To Shift To 2 Nd Gear I Have To Play With The Gas To Get It To Shift. Is My Transmission Ready To Get Rebuilt Or Replaced?
Thanks For Yor Time.
Rick
Old 06-29-2004, 12:10 AM
RexNfx400's Avatar
You could have the vacuum modulator, vacuum and kickdown cable checked. If they are OK, then maybe the governor valve or vavle body is sticking. If a valve is sticking then pretty much time for a rebuild. These(trannys) will start to "hang" valves as the metal and friction material floats around inside the tranny. It is a easily contaiminated tranny.
Also, if the engine is lacking power it can shift late also. Make sure to have the simple stuff checked first...
Good luck
4l60e Transmission out again...need help remington8189 Silverado 6 10-08-2014 04:16 PM
transmission not engaging guys i need your help cyberfastpush Trans Sport 1 03-12-2010 04:58 PM
Transmission Help Funkybassjayk Grand Cherokee | Grand Cherokee SRT8 1 01-28-2010 11:37 PM
Help! 94 2jz 6spd...transmission noise warman724 General 1 11-29-2009 09:21 AM
NEED HELP!!! Dodge Ram Slipping Transmission jon2dope1987 Ram Pickup | Ram SRT10 2 09-04-2009 01:58 AM
