Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-14-2004, 06:08 PM
Webslinger60 Webslinger60 is offline
Using water to clean the combustion chambers
What do you guys think of running water through the engine to clean the combustion chambers? Lets say you suspect a sticky valve, due to sludge on the top side & not closing 100%.
I’ve gotten a few different opinions.
One mech used to actually pour water into the carb at fast idle, with no problems. Then again my dad saw a guy blow an engine using just an eye dropper. The safest way I was told was to use a spray-bottle on “wide/mist”, and no more than a quart.
Then again, wouldn’t water just clean the underside/combustion-side of the valve and NOT the top where the sludge is?
I was also told to used GM’s “Top engine cleaner" "Seafoam" or other things. Im not crazy about solvents. A little sludge on hi-mile rings is not a bad thing. If you dis-lodge it, the cylinder may start to smoke.
Old 03-14-2004, 06:57 PM
burnM's Avatar
burnM burnM is offline
Re: Using water to clean the combustion chambers
I've seen people use everything from water to tranny fluid. Just put some water in a pop bottle, and use a vacuum line from the carb. Stick a tee fitting on it so you have an extra line to work with. Put the carb at fast idle. Take that vacuum line, put it in the bottle and pinch the line. Release the line a little bit. When you hear the engine bog, pinch the line again. Continue until you've used up about 1/3 of the bottle. Just make sure you have good neighbours before you do this. The smoke will be quite thick. I've never blown an engine this way and never heard of anyone else doing it either.
I've used that trick to clean carburator throats as well...however you should change your plugs afterward. That crap has to end up somewhere, usually sticks to the plugs.
If you feel uncomfortable doing this, take your car to a shop to get the 'engine vac' service. It takes about 30 min. to an hour. It is claimed to clean carbon and sludge from the entire engine.
2 cents
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 03-14-2004, 07:36 PM
bduff509's Avatar
bduff509 bduff509 is offline
Sounds like a good idea. I'll have to try that. Same with TBI ? Anybody remember the stuff Gummout used to sell back in the '70s? I believe it was a complete fuel system cleaner that was fed directly into the fuel line into the carb. My cars always billowed white smoke when I used it. Worked great though. I think they took it off the market when cats got too common.
Old 03-16-2004, 03:54 PM
I’ve been told water is the most dangerous, because of the sudden compression change and Im better off with a petroleum based solvent. I’ve been told to try:
8oz of brake fluid or ATF
10oz of diesel,
12oz of Marvel oil
Whole can of GM Top Engine cleaner
PB Blaster aerosol (something like liquid wrench or rust buster) through a vaccum line.
Or something else called “Seafoam”
Any opinions?
Old 03-19-2004, 10:51 PM
70z 70z is offline
Water injection has been used succesfully for years to help guard against denotation. I plan to run a water/alcohol injection system on my blown BBC. Set up to run during boost only. Get a more complete burn, Cleans, and Cools.
www.dawesdevices.com/water.html
This site explains it. This is not the system I am going to use, however it does explain the principles behind it.
What do you use to clean the inside of your car? Green Machine 95 Aurora 17 02-08-2005 12:39 PM
Using water to clean the combustion chambers Webslinger60 Engineering/ Technical 9 05-31-2004 11:31 AM
Using water to clean the combustion chambers Webslinger60 General Discussion 10 05-21-2004 03:15 PM
Using water to clean the combustion chambers Webslinger60 General Discussion 2 03-16-2004 03:58 PM
Using water to clean the combustion chambers Webslinger60 General Discussion 0 03-14-2004 06:03 PM
