Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 03-14-2004, 06:03 PM
Webslinger60 Webslinger60 is offline
Using water to clean the combustion chambers
What do you guys think of running water through the engine to clean the combustion chambers? Lets say you suspect a sticky valve, due to sludge on the top side & not closing 100%.
I’ve gotten a few different opinions.
One mech used to actually pour water into the carb at fast idle, with no problems. Then again my dad saw a guy blow an engine using just an eye dropper.The safest way I was told was to use a spray-bottle on “wide/mist”, and no more than a quart.
Then again, wouldn’t water just clean the underside/combustion-side of the valve and NOT the top where the sludge is?
I was also told to used GM’s “Top engine cleaner" "Seafoam" or other things. Im not crazy about solvents. A little sludge on hi-mile rings is not a bad thing. If you dis-lodge it, the cylinder may start to smoke.
What do you use to clean the inside of your car? Green Machine 95 Aurora 17 02-08-2005 12:39 PM
Using water to clean the combustion chambers Webslinger60 Engineering/ Technical 9 05-31-2004 11:31 AM
Using water to clean the combustion chambers Webslinger60 General Discussion 10 05-21-2004 03:15 PM
Using water to clean the combustion chambers Webslinger60 General Discussion 4 03-19-2004 10:51 PM
Using water to clean the combustion chambers Webslinger60 General Discussion 2 03-16-2004 03:58 PM
