Old 03-14-2004, 05:07 PM
sandy809 sandy809 is offline
Need help with a problem
I am having a problem with my Camaro. It is a 1998 6 cylinder 3.8 liter engine. A few weeks ago the check engine light came on, and started blinking only when I would accelerate. I had it checked and it said there was a misfire in cylinder 6. (I just replaced the plugs and wires less than 10,000 miles ago.) My mechanic looked at it, replaced one of the fuel injectors, cleaned the rest and then put a bottle of fuel system cleaner in with a full tank. This seemed to repair the issue. However, about 800 miles later, the light is one again. This time it is detecting a misfire in cylinder 5. It is idling rough and chugging when I accelerate. It seems to surge sometimes too. A bottle of fuel system cleaner made it a little better, but did not resolve the issue. It now will also blink when I am sitting a light. My plan was to replace the fuel filter to see if that helped...any ideas? I don't want to have to take it somewhere and have them play trial and error until they find the problem.
Old 03-14-2004, 08:01 PM
wickedwayz wickedwayz is offline
problem
sandy i had the same prob with my 97 had fuel pump replaced and blamo no prob
Old 03-14-2004, 08:54 PM
Re: Need help with a problem
how much did that run you?
Old 03-14-2004, 09:37 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
the fuel pump is probly around $60-100. there a bitch to change, you gotta remove the exhaust, torsion bars, and fight with the filler neck
Old 03-15-2004, 07:47 PM
it was under warranty but its gonna be a chunk of change
Old 03-15-2004, 09:18 PM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
not all the time i have helped my friend replace his pump by cutting an access pannel in the hatch. pulled up the carpet and pulled the pump out and it took like 5 hours! we just put hindges on it anda latch to make it easy access. but as for your problem try the igniton coil or the destributior. but humm thats about all i got for that problem
Old 03-15-2004, 09:31 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Mine did the same thing, and just by the symptoms I assumed it was misfire, but later found it it was my transmission.
Need help with some major problems with 95 probe Feicht Probe 5 09-10-2004 01:33 AM
need help with problem, motor djnoodle '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 12-02-2002 04:05 PM
Need help with a painting problem primera man Car Modeling 15 07-10-2002 07:57 PM
really need help with this bulb problem... solomon Integra 5 02-11-2002 01:56 AM
need help fuel problem with my civic.! Spinalfury '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 12-22-2001 06:49 PM
