Old 12-02-2002, 08:45 AM
djnoodle djnoodle is offline
need help with problem, motor
92 civic si. i got the car about 5 months ago and started driving it for about a month when the battery light came on, i checked it out and my belt for my alternator came off, upon further inspection and about a 6 hour job we had to take the alternator out. the tension bolt broke off and half of it was in the alternator, the other bolt, i guess the mounting bolt was also missing, so it was hanging on by the cables, we got all that done and it worked, about 2 months later the tension bolt broke again, once again we got it out and replaced the bolt. after that about every 3 weeks the bolt got loose and i would have to tighten it up again. yesterday it broke off again and i am getting pi$$ed. should i just get a really strong a$$ bolt or my freinds said that i should get new motor mounts, how do i check to see if my motor mounts went bad? any ideas or suggestions on what i should do?
Old 12-02-2002, 01:56 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
try replace it again but this time put like a teflon tape on the bolt so it wont get loose. also are you torquing these bolts down to the proper specs or just making it as tight as you think it should be ? maybe you are making the belt too tight so it puts alot of pressure on the bolt and the belt. also you always say the tension bolt breaks, but what about the mounting bolt, is that fine ?
Old 12-02-2002, 04:05 PM
shepworldwide's Avatar
shepworldwide shepworldwide is offline
check to see if there is any cross threading...and what killa said
:twoguns:"shepworldwide":twoguns:
96 integra for sale or trade
huge northest meet may 31st. come check it out.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
