Old 03-14-2004, 03:08 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
EVOIII o2 sensor housing
Im looking to get a new o2 housing b/c mine is fucked, is the evoIII a direct bolt on even with my 2g manafold and will the o2 sensor i bought to replace my stock o2 fit in the evo O2 housing or will i have to get one for a evoIII
Old 03-14-2004, 05:42 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: EVOIII o2 sensor housing
o2 housing doesn't bolt on to your manifold, but yes it will fit. I don't know if a 2g o2 sensor fits in it, but you should be able to find the o2 sensor for the evoIII and see if it's the same one.
Old 03-15-2004, 08:15 AM
kjewer1 kjewer1 is offline
AF - Advisor
All modern O2 sensors are M18, so stocker will fit. The bolts to the downpipe are spaced farther apart than the stock one, so if your DP doesnt have slotted bolt holes, your going to have to modify the flange. The angle is also different and some DPs will hit the transfer case. OTherwise, yes, its "bolt on."
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-15-2004, 09:00 AM
cool ok thanks
PCE
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
Engine Coolant Temperature sensor housing pcampbel Explorer | Explorer Sport Trac 1 11-11-2007 02:04 PM
02 sensor housing and 2.5" exhaust want_a_stealth Eclipse Problem Diagnosis 2 07-14-2006 12:57 AM
o2 Sensor Housing 90EclipseGsx Off-Topic 1 01-18-2005 03:18 PM
oil pressure sensor housing leak? 4bz Grand Cherokee | Grand Cherokee SRT8 2 01-04-2004 05:43 PM
