Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-13-2006, 11:14 PM
want_a_stealth want_a_stealth is offline
02 sensor housing and 2.5" exhaust
i just bought a 91 gsx and it has a bad case of idle surge. starts idling at around 1.5k and then when i drive the car for a while, it idles from 1.5k to 2k.
i have read a ton of info on this and at first, i thought it was the idle sensor thing that was causing it.
ever since i bought the car, i can tell that the exhaust fumes are going into the car, and i can smell it when i am driving. i popped the hood and the first thing i saw was the o2 sensor housing and the aftermarket exhaust. the problem is that the end of the exhaust, which hooks up to the 02 housing, seems to be bigger in size, plus, the whole where the nut connects the housing and exhaust, seems to be cracked(on exhaust).
what do i have to do to fix this? would i have to get a whole new downpipe in order for this to be fixed?
Old 07-13-2006, 11:24 PM
Killa's Avatar
Killa Killa is offline
Re: 02 sensor housing and 2.5" exhaust
Dude post in the right forum, dont give admis here a hard time, moving topic around.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-14-2006, 12:57 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Check and make sure the ISC is plugged in. If it is, I would think the ISC itself is bad.
If theres a crack on the down pipe, thats what I would assume is leaking exhaust. You should get a new one, or you can weld up the one you have.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
