Exhaust Manifold...
Hello Everyone! I am 16 and got a nice fiero, which I am fixing up at this moment. I just need to do a couple of things. I was just wondering, I am have crack on my exhaust manifold, so what should I do? Shopuld I go get another one or maybe put some kind opf sealing stuff on it?
For the cost replace it, not realy worth welding unlees you can do it or have it done cheap. But then again a weld on the manifolds don't really last most of the time.
Re: Exhaust Manifold...
Also, when i push the petal to the floor, the car makes a sound and hesitates for a second before it takes off. Does anyone know what is wrong? It has just started. My car as 166,000 miles on it, does that have anything to do with it, maybe a part or something?
What kind of a sound when you floor it? Backfiring sound like a pop?
What has been replaced on the car recently? Can you give us a little more background info? At first idea, have you checked the timing? Could be many other things too. |
The sounds is like a rumbling sound and shakes for only a second and then takes off, but it only does this when i punch it to the floor. If I take off slowly and then punch it does not happen. I resently just changed oil, changed heater core, and belt. Dis. cap was replaced not to long ago. I just put a new K&N air filter in the car bout a month ago. Some backgorund on it is. The car is a 86' Fiero SE with 166,000. The belt breaks every 1,000 to 2,000 miles because of rusted pulleys, but i just bought a set of underdrive pulleys. As you see I also have a cracked mainfold. At first I thought that i let the gas get too low or the sprak plugs or wires becasue i could use new of them too come to think of it. the plugs are good becasue i checked them all, but the wires I looked at them all and found one cut, so I replaced it.
Is your car an auto or stick?
My Stable: 2002 Yamaha YZF-R6 1988 Pontiac Fiero 1969 Pontiac Firebird I might get my '02 SS back.... |
It is an auto.
u have a 4 cyl or 6 cyl ?
Midnightryder u have a pm
6 cyl...
Could be slipping clutch packs, or a bad tranny pump. (The shaking thing) Anyway, that's my best guess.
Alright I wil check into that. Thanks...It could probably use a tune up also. So this weekend I am going to put a dis cap, spark plugs and wires to see maybe if that will help.
Would it be a good idea to put headers on the fiero, instead of replacing my cracked mainfold? |
Well today...I just finished putting new spark plugs wires on my car. Next week I will be putting underdrive pulleys and a fuel filter on hopefully depending on weather...haha...i still have not fixed the problem, but dammit i will. lol
new question: how much would it cost to get someone to rebuild my engine because i think it could use it??? tomorrow i am going to put a set of underdrive pulleys on my car finally...w00t
how much power do u think they will add...10-15 hp?? i put a k&n air filter...do u think it added anything besides make it breathe better??? and last week i put a new set of spark plug wires on becasue the other were falling apart plus...found one crakced..=( |
Re: Re: Exhaust Manifold...
![]() With labor a rebuild like that I'm guessing would run you $1600-$2000 A decent freshening up, including a head job, re-ring, bearing and gasket replacment would cost under $1000, I assume. This would only apply if the engine was in good, non-abused condition. Neither of my guesses involved labor for pulling/reinstalling the engine in the car. Quote:
Slowing down the water pump on a Fiero is going to overheat it!
Wanted to buy: 86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply. 74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!! 3Rd gen F body floor pans/camaro door skin (L) Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
