Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-17-2001, 03:16 AM
ty423's Avatar
ty423 ty423 is offline
Send a message via AIM to ty423
Bluebird Exhaust manifold question
I bought a BB manifold and it doesn't have the EGR out. What should I do and would it trigger the ECU if I don't use it? What can I do?
Old 11-22-2001, 06:35 PM
ty423's Avatar
Doesn't anybody have any idea? please help
Old 11-22-2001, 09:34 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
i remember reading that for the BB, just plug up the EGR hole with a rubber patch.
1.6 - The Underdog
GA16DE-T Club!
Old 11-22-2001, 09:41 PM
ty423's Avatar
Is that all?? will I get Check Engine light?
Old 11-22-2001, 10:52 PM
AznVirus's Avatar
i dont think so, just patch it up with those rubber caps. and clamp it.
1.6 - The Underdog
GA16DE-T Club!
Old 11-22-2001, 10:54 PM
ty423's Avatar
Its not going to affect my low end? I read somewhere that the EGR opens on low throttle and closes at high throttle. This isn't going to affect anything?
Old 11-23-2001, 12:06 AM
AznVirus's Avatar
i dont think it would hurt anything, all it does it recirculate exhaust gases back into your intake manifold. and if you think about it, your sending HOT air into your engine, which would probably affect it in a bad way.
http://members.tripod.com/~Pre_ludE/pmods.html
it says it will set off the check engine light, but thats cause of emissions and all that shit.
1.6 - The Underdog
GA16DE-T Club!
Old 11-26-2001, 04:10 PM
APEXSER APEXSER is offline
EGR
Are you running a JWT ECU? If so, they can program the ecu to run without the EGR! If you must have EGR, the you can have someone weld a fitting from your stock manifold to the Turbo Manifold! I would say just get rid of the EGR completely and make a cover plate for the EGR port on the intake manifold!
Louis Anaya
1992 Nissan Sentra SE-R Turbo
12.0 @ 118.77 mph
349.6 HP & 301.9 FT/LB
SR20 Performance
www.sr20performance.com
480-966-SR20
480-966-0100 Fax
Old 11-26-2001, 05:36 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Congratulations Louis, I believe you are now the fastest person/car in this forum. SR20 powered that is. :hehe:
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-26-2001, 10:24 PM
ty423's Avatar
Thanks for the info. I checked your site. You got one nice ass ride. Will I trigger the ECU?
Old 11-27-2001, 07:43 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
If you get a JWT ECU he'll bypass the EGR and you won't get a light.
Old 11-27-2001, 06:26 PM
I just figured I could help out in here with some technical questions!
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
Old 11-27-2001, 09:02 PM
G-Forces's Avatar
Banned
The more the merrier!
BTW did George point you here?
Old 11-27-2001, 09:32 PM
ty423's Avatar
Maybe you guys can help me out some more here. Yesterday I sent in my turbo to be rebuilt with a new compressor wheel. Today I got a call saying they can't do it. The reason? The compressor wheel is not available here in the states (supposedly). I bought this turbo used with the manifold and heatshield. The guy I bought it from said it was from a Nissan Bluebird. The turbo place thought that it was a typical Z32 turbo but looked up the turbo number badge and it matches no car in the Garrett guide. Where do you think I can get a T25 A/R 80 wheel? Turbo model number 466075-2 Garrett. The place I went to is www.turbocity.com
Old 11-28-2001, 08:44 AM
I have been on this list since, August, I just haven't posted here much! When I first signed on here, there wasn't much activity!
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
