Old 03-14-2004, 12:51 PM
Vegas Gambler Vegas Gambler is offline
95 Blazer missing and rough Idle.
Hello all,
I have a 95 blazer that all of a sudden started missing. It just had a semi-new engine dropped into it. We where on our way back from a trip when it lost power and would not climb hills. On the flats it will do 75-80 MPH. It has no power. I thought that it may have been bad plugs or wires. I pulled the rear drivers side plug and the electrode was missing. (See picture)
Sorry for the crappy pictures.
It doesn't smoke but it does smell like gas. Also it pings really bad. I have changed the plugs (PITA) and it still did not help. The service engine light has not come one. To me it sounds like it jump time but I don't know. Thanks for a suggestions.
Old 03-14-2004, 07:22 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 95 Blazer missing and rough Idle.
get the codes pulled hopefully the engine isn't completely destroyed there are a few things that cause detonation such as a lean condition, bad knock sensor, heat range too high on plugs. i would do a compression check before throwing parts at it it's very possible you dished a valve or cooked a piston.
Old 03-14-2004, 10:04 PM
Well I took it to my dad and he thinks that it sucked a valve. I will call the shop where they put the new motor in at. Was only done 2 weeks ago. I don't know if they will do anything. Oh well. Thanks for the info.
Old 03-15-2004, 10:26 AM
Ok well just got back from the shop. The guy thinks it's the connecting rod. So, they are going to pull the motor and replace it again.
Repair Manual and Rough Idle jpar1983 Intrigue 4 09-21-2011 03:59 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
97 Blazer with High Idle when MAF unpluged and rough idle when pluged in at startup ndgely Problem Diagnosis 6 12-18-2008 08:48 PM
85 Celica Tech. Missing and rough idle. is0crazy Celica 5 09-05-2006 12:28 PM
