Old 12-08-2008, 05:30 PM
ndgely ndgely is offline
Unhappy 97 Blazer with High Idle when MAF unpluged and rough idle when pluged in at startup
Hello All,
I have a 97 Blazer with High Idle(900-1100 RPM) when MAF unpluged and rough idle when MAF pluged in at startup. I was having issue with it starting up, I had to pour GAS in the carb in order to start. I was suggested to replace the Fuel Pressure Regulator. Once I did that, I have the rough Idle at start where I cant even backup without it turning off. What I discovered if I Unplug the MAF the car startsup but idle very high. If i leave plugged in the idle varys from high to low then becomes rough.
Any ideas would help. 97 chevy blazer, V6 4.3. So far replaced fuel pump,fuelfilter,battery,ignition switch,MAF(bone yard) and fuel pressure regulator.
Old 12-08-2008, 06:40 PM
old_master's Avatar
Advisor/Moderator
Re: 97 Blazer with High Idle when MAF unpluged and rough idle when pluged in at startup
Is the SES light on? If so, what DTC's are in memory? Have you checked fuel pressure and leakdown?
Old 12-09-2008, 04:09 PM
last code I had pulled was P0174 to lean prior to fuel pressure regulator. I have not checked after installation.
Old 12-09-2008, 08:53 PM
old_master's Avatar
Advisor/Moderator
Pouring fuel in to get it to start, is a classic symptom of low fuel pressure. Low fuel pressure will also set the P0174, and cause a rough idle.
Key on, engine off, fuel pump running, fuel pressure must be 60psi to 66psi. After the fuel pump shuts off, pressure must remain above 55psi for 3 to 5 minutes. Post your results.
Old 12-11-2008, 01:37 PM
Unhappy Re: 97 Blazer with High Idle when MAF unpluged and rough idle when pluged in at startup
Pulled codes, now I have P0102,P0507. I pulled out the IAC(sits on bottom right of carb) and noticed the tip was cracked is this normal because how would it screw off to clean.
Old 12-18-2008, 02:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Replace the IAC, replace the MAF.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-18-2008, 08:48 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
I'd probably replace it too.
Do you have a local Library near-by.
If so, go and look up the ohm range the IAC should put out.(if you have a ohm/multi-meter).
A couple of the repair manuals at my library list these types of specs.
Saves the cost of throwing money at the thing (which I've done quite a bit of)
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
