Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-14-2004, 10:30 AM
ackyoura ackyoura is offline
vtec
I have a question. My Vtec kicks in at 6 grand, and is killed by the rev limiter at 7. The Vtec doesnt pull nearly as hard as a b16. I started to check the vtec soleniod, and found that the blue/black wire doesnt have 12 volts from the PCM. Any ideas???
Old 05-24-2004, 11:38 PM
95 geser 95 geser is offline
Re: vtec
you have a gsr, and its limiting at 7000,u should check wat kind of ecu you have,vtec should be from 4500 to 5000 depending on conditions,and it shouldent limit untill 8100
Old 05-25-2004, 12:02 AM
dc2_bountyinteg dc2_bountyinteg is offline
Re: vtec
your distributor may need to be rebuilt. is your ecu throwing a code? if so check it at hondata
Old 05-25-2004, 01:25 PM
scallywag scallywag is offline
Re: vtec
GSR has a 2 stage vtec, The first should kick in at around 4500, and the second at a little over 6000. But your rev limit shouldn't cut fuel till about 85000. Even though the red line is at 8100, mine cuts at about 8400-8500. Check your ecu like mentioned above.
vtec or not vtec gwako Engineering/ Technical 20 05-05-2003 11:22 AM
whats the difference in the 4th gen si vtec and the vtec Got Boost? Prelude 10 08-31-2002 04:31 PM
Vtec Head on Non-Vtec? H22-Civic Si '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 05-19-2002 07:59 PM
Difference in VTec between Si and Vtec models? 69GPrix '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 05-11-2002 11:07 PM
ls/vtec how about a f22/vtec crazy_ss Engineering/ Technical 9 01-19-2002 11:32 PM
